Anonymous1
There are also customer processes that are “leaner” and easier to use with Wingo than with “blue”.
For example, public IPv4 is just a click away on the customer portal and can be activated directly by the customer:
    2 years later
    Werner Wingo is terrible when it comes to their support.
    I’m trying to set up a server to play Minecraft together, need port forwarding and have been trying for hours to figure out how to enable port forwarding on a Wingo Internet Box 2. Your solution is the best I’ve found so far but I can’t find these settings anywhere. https://www.wingo.ch/de/hilfe/faq/welche-art-von-ip-adresse-erhalte-ich-bei-wingo is wingo’s “solution” what to do?
    • Sc00by has responded to this post.
      Plimpopleu71 You can do the port forwarding directly on the Internet Box. Under the menu item “Network”. If you do not see port forwarding, you must activate expert mode.
      Have you activated the public IPv4 address in your customer account? Otherwise you will never reach your server.
        Plimpopleu71 you’re in the wrong account. There is one for the mobile phone subscription, then another for internet and landline. You can see the email address stored in your contract. If it is the same as for the mobile phone subscription, you can access the other account at the top right by clicking on “Change account” or you will be asked which account you want to access after logging in.
        [unknown]
        If you are logged into Wingo Mobile MyWingo, there is a profile button at the top right, where you can switch to the Internet account
        ….keep on rockin' 🤘🏼🤘🏼🤘🏼
