@PeterM1
Of course you can attach a photo directly!
N.B. Have you already completely reset the repeater?
I once unplugged all devices before resetting the Internet-Box 2 and then plugged them in again one at a time!
    WalterB
    Hello WalterB
    Thanks for the tip about the photo file… anyone who can read is clearly at an advantage:smileyvery-happy:
    I have already reset the repeater several times, switched all devices off/on (disconnected from the mains, as it says in the first post) and then integrated them back into the home network one after the other. I had to do this because I wanted to describe the imaginative names of the various devices in a clearly recognizable way.
    Thanks for your help and best regards
    PeterM1
    Here is the current device list of the IB2
    Here is the RPT from an archived device list
    Here is the current WLAN diagnosis in the IB2
    I saw that you have a lot of WLAN kit in use, try turning them all off and then try again to connect the repeater to the Internet box.
    I also assigned my repeater a fixed IP address outside the range of IP addresses of the Internet box, e.g. 192.168.1.199
    • PeterM1 has responded to this post.
      WalterB
      “I saw that you have a lot of WLAN kit in use, try switching them all off and then try again to connect the repeater to the Internet box.”
      I’ve done this several times, without success.
      “… assign the repeater a fixed IP address outside the range of IP addresses of the Internet box, e.g. 192.168.1.199”
      I wanted to try that, but how exactly do I do that if the RPT doesn’t appear anywhere? Do I then change the IP in the RPT itself? Attached is a screenshot of the RPT.
      Greeting
      PeterM1
      WalterB
      Does it make a difference whether I access the RPT via the browser/IP address or via a LAN cable via PC?
      • When I’m in the RPT menu…
      …do I change the IP to e.g. 199 and leave “Automatic” activated, or do I have to change it to “Static”?
      • I don’t have to make any changes to the IB2? After changing the RPT IP, the IB2 has to be restarted, that’s clear to me. But how does the IB2 know that outside its rank ( up to 161) there is still a device connected to the network?
      I’m starting to feel a bit confused….:smileyfrustrated:
      Thank you for your patience…
      Greeting
      PeterM1
      • WalterB has responded to this post.
        2 months later
        user109 wrote:
        What are the login details for the repeater? BN: admin PW:?????
        Thank you
        See image below when first entering the menu.
        Or at the link:
        https://www.swisscom.ch/de/privatkunden/hilfe/geraet/heimvernetzung/wlan-repeater.html#tab-group_26e8-tab_c227b9cd4bf8-2961-4032-8c94-739cc199dc39
        a year later
        MCU
        What problem exactly, there were several different questions asked in this thread?
        N.B. if I connect the WLAN kit directly to the IB2, e.g. as an access point then it is displayed with IP address etc.
        However, it can take up to 5 minutes for it to become active.
        Hello MCU
        It’s been a long time, but I disposed of all the AirTies professionally:meh: and further Two new ones from Swisscom WLAN boxes purchased. Their range is significantly better than with the repeater stuff. Although all Swisscom employees assured me that it “should” work with the repeater. This is how you boost sales:winking:
        Greeting
        PeterM1
        I’ve had the new WiFi boxes myself for a long time, but I use the old WiFi kit for guests temporarily because it’s not yet possible to use the guest WiFi via the new WiFi boxes.
        But it’s true that the new WLAN boxes have much better performance and practically no problems, and activation is also super fast.
        a year later
        I have recently had the IB3 repeater AirTies 4920, which I have been using for a long time in 5GHz without any problems. The problem is that the repeater apparently cannot handle the standard IPV6 802.11 ax. Switch off and set the channel to the older channels on 36-52. The frequency is then reduced to 80MHz instead of 160, but the 5GHz diode lights up a pleasant blue again on the WLAN adapter. There is a driver update that I couldn’t install. Otherwise you will have to switch to the WiFi box that supports the latest standards.
        @Dograplie44 use a WLAN-Box or wait a while until the WLAN-BOX 2 comes.
        ([https://www.swisscom.ch/de/privatkunden/produkte/netzwerkzubehoer/details.html/wlan-box-11024867?payOption=ONE\_TIME&useCase=HARDWAREONLY&category=connection\_accessories\_RES&d s_rl=1241293&gclid=Cj0KCQiAz53vBRCpARIsAPPsz8Vpv4TLyDE0ekCp_tEMfa5YMttmZxfcpp_Nj_sFXA YBERuhi5W2hGwaAviVEALw_wcB&gclsrc=aw.ds#tab%5Bselected%5D=0&campID=SEA_SE_RES_POR_R1G R0697](https://www.swisscom.ch/de/privatkunden/produkte/netzwerkzubehoer/details.html/wlan-box-11024867?payOption=ONE_TIME&useCase=HARDWAREONLY&category=connection_accessories_RES &ds_rl=1241293&gclid=Cj0KCQiAz53vBRCpARIsAPPsz8Vpv4TLyDE0ekCp_tEMfa5YMttmZxfcpp_Nj_sFXAYB ERuhi5W2hGwaAviVEALw_wcB&gclsrc=aw.ds#tab%5Bselected%5D=0&campID=SEA_SE_RES_POR_R1GR0697)) instead of the AirTies 4920.
