I filled in the SIP server field
which you have not completed.
The SIP Proxy server needs to know which server to redirect its content to the SIP server.
The rest is the same.
@seyfcom wrote:
@pioupiou hello
Can I have an idea of ​​the settings you made on MicroSip please! thanks in advance!
2 months later
Good morning,
Has anyone already configured a Mitel phone with Swisscom SIP Credentiel? I got a 403 error message while checking.
Basic SIP network settings
Proxy serverswisscom.ch
Proxy Port0
Backup Proxy Serverswisscom.ch
Backup Proxy Port0
Outgoing proxy serverfs1.ims.swisscom.ch
Outgoing proxy port5060
Backup Outbound Proxy Serverfs1.ims.swisscom.ch
Backup Outbound Proxy Port5060
Registrar Serverfs1.ims.swisscom.ch
Registration port5060
Backup Registrar Serverfs1.ims.swisscom.ch
Backup Registrar Port5060
Registration period180
Conference Server URIfs1.ims.swisscom.ch
Thank you for your help and best regards.
Good morning,
Proxy Port0
Backup Proxy Port0
@Kieppessioy31
see this post on the German-speaking community by POGO1104 from April 7, 2019
Mitel 6863i (Google Translate)
_Would you like to operate in a Centro Business or in a Swisscom Internet box?
_
With the “external” information SIP Credentials , you are looking at:
SIP Credentials
With local SIP credentials on the internet box you can watch:
Configure local IP telephony
_EDIT:
I found in the Digitec forum:
Compact instructions:
Swisscom (local IP telephony access data) -> Mitel (line 1):
Login Name -> Authentication Name
Login password -> Password
Internal -> Telephone number
Private -> Screen Name
The rest of the fields_Basic SIP Authentication Settings_are empty
Internal IP of the router Swisscom Routers -> Proxy Server, Outbound Proxy Server, Registrar Server
5060 (port number) -> Proxy Port, Outbound Proxy Port, Registrar Port
3600 -> Registration Period
Remaining fields in Basic SIP Network Settings as 0.0.0.0 or 0, Conference Server URI empty
Remaining fields on Standard
Both of my Mitel phones work with it. I have two Swisscom lines. Both phones ring for incoming calls on both numbers. They indicate with the line light or ringing the number called. To do this, I defined 4 connections on the Swisscom router (one connection for each telephone and each of my numbers). With outgoing calls, you can choose which number to go out with.
You can talk to each other internally, even if it wasn’t a requirement._
[Question about Mitel 6863i](https://www.digitec.ch/fr/s1/QuestionAndAnswer/will-this-phone-be-compatible-with-the-new-swisscom-internet-box -as-they-close-their-analogue-connec-70417)
    8 days later
    Hello everyone
    I am trying to configure my Yealink T46G with this configuration, but without success. I have an OVH account for a French number, no problem. Just Swisscom which doesn’t work.
    Thank you for your support if you managed to configure it or your idea welcome. I specify it is not a swisscom (tel)
    https:myalpinecare.ch/t42gprob.jpg
    Thanks in advance
    Stephanie
    @Alpinecare
    > I specify it is not a Swisscom (tel)
    Yealink on a connection with subscription inOne Home or inOne SME at Swisscom
    Then connect with SIP Credentials to an Internet Box
    for a complete and professional response
    call the Hotline for Clients commerciaux 0800 055 055 (it is also possible to be called)
    or contact by formulaire
    @Alpinecare Hi Stéphanie,
    I don’t want to be mean, but when you don’t know, the best thing is to contact professionals… And looking at the first page of the post, you would have seen a photo of the config that I posted…
    You have reversed the fields “username” which is the telephone number and “registration name” which is the NC….@swisscom.
    You just had to identify the data and fields that are the same!
    Reversing that should work.
    Roman
    PS: it may take 1-2 minutes for the connection to register or even to restart the device.
    @RSA Hello Romain Thank you for your answer, wouldn’t your answer be a little sexist? 😓 yes I am a woman and I like to learn and if I really can’t anymore I ask for help.
    You’re right, I skipped this error, but it still doesn’t work 😞
    Good day
    Stephanie
    @“x”#203476absolutely not sexist^^ I would have made the same comment for a guy 😉
    Afterwards, for a landline, this phone is preferable in my opinion:
    https://www.alltron.ch/fr/product/141437
    If that doesn’t work, I would check the password, because between O or 0 you can easily make a mistake or with I and l…
    the ideal is to copy and paste the password. You must also check the internet connection above as well as the IP parameters
    9 months later
    Hello Black Mamba, I configured a Yealink T46G (with unrestricted Yealink firmware) and it works well with local SIP credentials. Internal calls also work. Unfortunately, call transfers do not work internally (from DECT to local SIP and vice versa).
    According to the packet captures I have made, the functionality is simply not implemented in the Internetbox. Do you happen to know more?
    In fact the transfer fails without error. I call the Yealink from a DECT, I transfer the call to a 2nd DECT. The Yealink is happy and from its viewing deck communication is complete. But the DECTs are still talking to the Yealink on silent lines.
    My intuition: although REFER is not offered by the internet box, the Yealink still tries and the box still responds OK, but without obeying. Would that be fair?
    @Le_Chat
    thanks for the contribution
    refer to the Swisscom help section
    HD-Phone Yealink T46G – Help | Swisscom
    and in particular in the section
    Divert calls and stay in touch – Help | Swisscom
    see also this information on the Community in German
    Gelöst: Yealink SIP-T48S - Anrufweiterleitung geht nicht | Swisscom Community​
    “However, for transfer to an IP phone (e.g. Yealink T46G, HD-Phone Sarnen), an additional number/line is required for inOne KMU Office.”
