LTE reception problem in Ticino - questions about coverage and a better antenna
Hello everyone,
I saw there are some experts on the topic here - unfortunately I’m a layman, so I hope I can
someone can help.
We have a holiday home in Ticino where I am struggling with significant LTE reception problems.
The setup looks like this:
- Router: Mikrotik wAP 4G kit
- External antenna outside: Mikrotik: mANT LTE 5o (5dbi)
Location and connections I saw:
Link to location: [Map](https://map.geo.admin.ch/?topic=funksender&lang=en&bgLayer=ch.swisstopo.pixelkarte-farben&layers=ch.bakom.mobil-antennenstandorte-5g,ch.bakom.radio- Fernsehensender,ch .bakom.mobil antenna enlocations-gsm,ch.bakom.mobil-antennenlocatione-umts,ch.bakom.mobil-antennenlocatione-lte&catalogNodes=403,408&E=2703660.23&N=1110464.48&zoom=7&layers_visibility=true,false,false,false,true)
Unfortunately, the cards are not all that accurate; most of the time the cell tower is connected to PCI 463 (above in the picture).
These are: rssi: -65dBm, rsrp: -87dBm, rsrq: -14dB, sinr: -2dB, cqi: 5
Speed less than 2 Mbit, frequency was probably 1800Mhz
The current SIM card is Sunrise, Swisscom was also tested with a similar result - it’s probably not the provider’s fault.
I was never able to get a connection to the nearest tower (below in the picture), even with my smartphone.
Even if there is a direct line of sight.
My question is:
I would now like to switch to a better directional antenna, which I point at the cell tower opposite (long green connection). I have a direct line of sight, with the one on the right in the picture, or all on the same bank, with hills in between.
However, I’m not sure whether I should get one for LTE or something future-proof for 5G (if I upgrade the router and it is made available).
The antennas I’m looking at are:
[https://www.fts-hennig.de/antennen/4g-lte/aussenantenne/antenne-lte-novero-mimo1800.html](https://www.fts-hennig.de/antennen/4g-lte/ external antenna/antenne-lte-novero-mimo1800.html)
or the one: [https://www.fts-hennig.de/FTS-Complete-All-5G-Antenne/](https://www.fts-hennig.de/FTS-Complete-All-5G-Antenne /)
I would be interested in your opinion on this…
I don’t understand why the mast directly in sight (bottom of the picture) isn’t used, are there more current maps?
I’m also not sure whether I should switch to 5G straight away…
Thank you!
