Asus RT-BE88U
Hello everyone,
I am thinking of buying the ASUS RT-BE88U router and have a question about the SFP+ port. I want to connect it directly to my fibre optic internet connection (OTO-Dose->BE88U)
Have any of you successfully connected the SFP+ port of the RT-BE88U directly to the OTO socket using a suitable SFP+ module and fibre optic cable?
I would be particularly interested:
Which SFP+ module did you use?
Did you have to make any special settings on the router or with your ISP?
Are there any compatibility issues I should be aware of?
Any insight or experience you can share would be very helpful!
Many thanks in advance!
