Partial block Internet
Swisscom has been disrupting our internet connection for about 3 months now. This means that the internet and wifi work, but gaming no longer works, neither on the PS5 nor on the PC.
PS5 is a closed system, so it cannot contain viruses/malware…
PC has already been scanned several times with different programmes… no viruses or malware found…
New internet box installed… theatre continues…
Does anyone know what this is all about?
Everything else works, except gaming.
The PS is completely blocked and can no longer access the network, at the same time TV works without a problem, all PCs and mobile phones can access the network, even the one where gaming is blocked…
That’s why I know that only the games are blocked
  • kaetho has responded to this post.
    Fleijupiet92
    ok, but that can have a number of causes, it doesn’t necessarily have to have been deliberately set up on your game console by Swisscom.
    The first thing I would do is replace the Swisscom DNS addresses in the router with 8.8.8.8, for example, and see if that improves things. If so, I would first ask myself whether the online connections you need for gaming are really the ones you think you are using.
      There is definitely no block “only for gaming”. Either the Internet is blocked as a service or not.
      This can happen due to outstanding invoices or spam / viruses etc.. But then nothing works at all and there are the corresponding messages.
      So there must be something else wrong with you.
      I would go first:
      • Delete the DNS cache on the router or better yet…
      • Reset the router to reset all settings
      • Do not accept any “better gaming this way” settings from any websites (port forwardings etc…)
      …and then take a look further.
      If you are stuck, MyService may be able to help you.
      changed by StefanSch
      Ich bin ein als Privatkunde getarnter Swisscom-Mitarbeiter im Bereich Service Continuity.
