You can check at www.swisscom.ch/checker.
Hello everyone.
First a “half” answer and then some questions from me.
Thirith: I don’t know exactly what it looks like structurally. As a customer, I experienced it 2 weeks ago that I previously had a 1Gbit/s subscription and was informed in Kundencenter about the option to upgrade/switch to 10Gbit/s. After about 1 week I received the Internet Box 3 (free) and the Anschluss was interrupted for half a day. I would also be interested in how and where this was replugged, since I still use the Anschluss 2 on the OTO. (Probably plugged in at the nearest data center/Swisscom headquarters) - but then 2 main lines would have to be run to my apartment building, one with a line for the new XGS PON technology, and one with several FTTH lines? Or do such splits still happen in distribution boxes in neighborhoods?
Again about FTTH and XGS PON, even if the super users are slowly going crazy with these discussions. I only learned about the techniques now that I have XGS PON 10 Gbit/s. The fear of wanting to share this with 32 participants was discussed several times. Nevertheless: Let’s assume that all 32 participants start huge, multiple downloads, does the splitter distribute the power fairly? So if 31 are already using bandwidth like crazy and I join them, will the speed of the others decrease, or will my bandwidth languish in the Mbit/s range until some capacity is freed up again? In retrospect, I also have some concerns as to whether I wouldn’t be happier with my own 1Gbit/s line with FTTH technology? I understand that performance bottlenecks can also arise if all users use too much bandwidth…
Edit: And yes, of course, I only have 2 or 3 devices on the box that only have 1Gbit/s network cards and I rarely use full power, or only for seconds…
What happens next with the two techniques? For example, is there both in Zurich, or in the longer term only XGS PON?
Something completely different: With XGS PON the signal goes encrypted (somewhere it said AES encrypted) to all 32 OTO sockets. How safe is that? Because of course, reading/scanning/recording up to 10Gbit/s of data and then decrypting it seems extremely unlikely. At least today… But what if an error/security gap is suddenly discovered in the encryption (e.g. always the same encryption and at some point someone finds out the key…). Or in 5 years you will suddenly find little boxes in China that you can attach to the OTO, where everything will be recorded automatically and the key will be calculated/found out with Cloud Power…?
In addition to this dream of the future: I have just made myself popular in another thread because I switch off my Internet Box 3 at night. (Why why can’t be discussed here, unless someone really likes it). But how safe is it these days with Internet Box 3, IPV6, the box’s firewall and Windows 10 if you have the box and computer switched on non-stop? I assume that you or your own IP would have to be targeted in order to have possible hacker attacks? Otherwise everything should be secure if you don’t negligently open ports yourself or tinker with the firewall too much?
@Chainsaw wrote:
Hello everyone.
Thirith: I don’t know exactly what it looks like structurally either. As a customer, I experienced it 2 weeks ago that I previously had a 1Gbit/s subscription and was informed in Kundencenter about the option to upgrade/switch to 10Gbit/s. After about 1 week I received the Internet Box 3 (free) and the Anschluss was interrupted for half a day. I would also be interested in how and where this was replugged, since I still use the Anschluss 2 on the OTO. (Probably plugged in at the nearest data center/Swisscom headquarters) - but then 2 main lines would have to be run to my apartment building, one with a line for the new XGS PON technology, and one with several FTTH lines? Or do such splits still happen in distribution boxes in neighborhoods?
Answer:
At the moment only FTTH connections are being converted to XGS PON technology. The splitter (1 fiber with 32 optically spliced fiber connections) is located in the control center in the OMDF rack (fiber connection distributor to the BEB -> OTO socket customer. It is possible to switch back to FTTH at any time. A different BK cable (breakout Cable) is switched to the customer’s Anschluss The same fiber optic cable is used regardless of whether it is FTTH or XGS PON,
With Mcan (FTTB/FTTC) only XGS PON technology is possible.
Answer:
First come first serve. The same principle as on copper, the provider makes a mixed calculation and, based on his experience, accepts overbooking of the Internet connections and determines his backbone connection capacity accordingly.
e.g. Xb/s on 255 VDSL connections (full expansion) on a DSLAM (PUS (Swisscom name) street distributor can contain up to 2 DSLAMS).
There are very few users who use the full connection power for >20 minutes or longer at a time.
Answer:
In the long term, XGS PON costs per port are cheaper than FTTH.
Answer:
If security gaps are discovered, they will be fixed promptly. This applies to the FW (OLT/router) and encryption. (ONT)
I think that in certain periods the encryption keys will be changed or increased to 256 bits if the encryption becomes too weak.
In addition to this dream of the future: I’ve just made myself popular in another thread because I switch off my Internet Box 3 at night. (Why why can’t be discussed here, unless someone really likes it). But how safe is it these days with Internet Box 3, IPV6, the box’s firewall and Windows 10 if you have the box and computer switched on non-stop? I assume that you or your own IP would have to be targeted in order to have possible hacker attacks? Otherwise everything should be secure if you don’t negligently open ports yourself or tinker with the firewall too much?
Answer:
That’s exactly how it is. Before a firmware for the router is published, it runs a pen test for possible vulnerabilities. I think paranoia about a hacker attack when the router is online 24/7 on a private Anschluss is unfounded. Unless I’m a company where there’s a lot to gain for the attacker or I’m interesting to the world’s secret services. But then I protect myself from an attack using completely different methods than constantly switching the router on and off.😁
Hello everyone,
Is there an update to the settings?
I’m trying to put the Sunrise 10G Anschluss into operation on a Zyxcel AX7501. Unfortunately, the FW doesn’t allow some things:
- Option 61 only allows one hex value, I can’t enter anything here
- Mac address of the original Sunrise box cannot be entered (Does Sunrise have a Mac lock?)
I tried the following configs:
- VLAN 10, 60 or 131
- Option 60 “dslforum.org,Fast5360-sunrise”
Thank you in advance for a few pointers
Yes, have you already contacted “Sunrise”?
https://www.sunrise.ch/de/privatkunden/hilfe.html
Here the help is mainly for Swisscom customers where customers help customers.
I can’t say whether the link from Swisscom is of any use.
[https://www.swisscom.ch/de/privatkunden/hilfe/geraet/internet-router/strangrouter.html](https://www.swisscom.ch/de/privatkunden/hilfe/geraet/internet-router/ foreign router.html)
Attention: Only routers and modules certified by Swisscom may be connected to the new 10 Gbit/s technology (XGS-PON).
Hello Walter,
I am absolutely aware that this is a Swisscom forum, thanks for the tip!
After the information in the post Solved: When will 10 Gbit/s come? – Page 4 | Swisscom Community from User109 were so good, I simply hoped there might be one Update 🙂
Contact Sunrise - I tried it. They currently offer 1 model, if by chance it doesn’t fit in the electrical box after moving, they don’t offer an alternative or support for specially purchased devices.
A Digitec customer described the following procedure for a Sunrise-XGS-PON-Anschluss:
Proceed:
1. Log in to 192.168.1.1 with admin
2. “Network Settings -> Broadband -> 1 GPON”: Delete this entry completely!
3. Add New WAN Interface.
4. We capture the interface on the image and confirm with Apply.
I don’t know if it works, but it can’t hurt to try it.
I very much doubt that Sunrise requires DHCP option 60 with the Swisscom string. They are more likely to have one of their own, but probably none at all. This is only intended for the ISP, but at the moment I think only Swisscom itself uses it.
What is important is VLAN ID 10 (for DHCP) otherwise nothing works.
As always, you can make your life easier if you clone the WAN MAC of the paired original provider CPE on the new device.
(BBCS and PON. One can only laugh)
für mich funktioniert das in Aarau(10G Sunrise over Swisscom network):
Mode: Routing
VLAN: Enabled
- 802.1p: 0
- 802.1q: 10
NAT: Enabled
IGMP Proxy: Enabled
Apply as Gateway Default: Enabled
Fullclone NAT: Disabled
6RD: Enabled
Check: option 43 & option 125
