See the same topic “Silverlight alternative”: https://community.swisscom.ch/t5/Diskussionen-%C3%BCber-TV-online-und/Silverlight-alternative/m-p/421626#M41 52
>“It’s been some time since Chrome stopped supporting native plugins.”
Well, just because a browser no longer supports the plugin (even if it is your “favorite browser”) is probably not a main reason for SC to immediately put all its resources and budget into the HTML5 alternative. As already mentioned, SC is certainly already on it. But building a new client ‘quickly’ will probably take some time (tests, etc.). I’d rather wait a little longer and have something that’s stable.
  • hed likes that.
I’ve been waiting for a long time too. In principle Silverlight wouldn’t bother me, it works well so far. But the quality leaves a lot to be desired. This is beyond HD.
@dominic_dg
The quality has nothing to do with Silverlight but with the codec used and the compression. Even with the successor solution, the image quality will not necessarily be better.
It’s always a balancing act, everyone wants maximum image quality with minimum bandwidth.
A solution like YouTube where you can choose the quality including auto mode that gets the most out of the available bandwidth would be ideal.
@madaley
I check it with my eyes, that must be enough because that’s how I earn my living. 3mbps is underground considering that the original signal comes from the transmitter at 50mpbs.
What bothers me is that I get a better picture via the same line on the box and via the iPad app than via my computer, which plays raw material at 350mpbs without any problems.
@hed
As I said, it’s not Silverlieght that bothers me, it’s the image quality. The video stream is simply compressed too much, although most computers can now handle the same stream as the Swisscombox.
@dominic_dg
It’s just the few who want solutions that aren’t built for the masses. 50Mbit per channel for all customers and ideally for all 4-5 computers in (your) household. If you really want the quality of the TV Box streams, there are already ways to enjoy this quality on your computer. You can take a look around and find out more about multicast on @Anonym’s blog. But the quality will most likely not be enough for you. Happy research…
@Anonymous
Thanks, some igniters with IE4.7 and 350Mbit just can’t be helped 😉
@madaley
You may have misunderstood me, the 50mbps from the transmitter is not what I need at home, I just meant that it was properly compressed from 50mbps to, as you say, 3mbps. If we assume a BBC documentary, these images are razor sharp on the television and on the iPad. If I were to watch the same thing on web TV, I could count the pixels, regardless of the size of my monitor. And I hardly believe that the stream to the iPad is higher than 5-8mbps.
Hi folks
>This is beyond HD
>…I get HD streams with 3Mbit…
That is correct. Online, the streams must be compressed otherwise you would have no chance on the mobile network. With LTE and eventually 5G, the bit rate may improve, but that will probably take a while. A “real” HD stream at home on the TV requires 8-10Mbit/s. This would be data overkill for mobile devices and reception and would not be of any use given the size of the mobile screens. Where you notice it most are the PC screens that can display a high resolution and where 3Mbit/s with a large diagonal does not ensure full HD enjoyment. There are different stream qualities (which you can understand with trace tools [i.e. Fiddler]), depending on what kind of device you use; The factors are the screen size of the device (i.e. iPhone4 vs. iPad), which image format (portrait vs. landscape player vs. full screen) and the reception quality (poor 3G vs. WiFi). The motto is ‘better to have poor image quality for an image at all’ rather than buffering and waiting for something to happen. Depending on the selection of these factors, the (dynamic) bandwidth is from 0.3 to 3 Mbit/s.
PS: A new web client wouldn’t change anything, except that a different codec might be used which compresses a little better.
9 days later
Watching TV on the Internet with the Swisscom TV subscription is so annoying!
Why is Swisscom not able to provide a better service?
I almost never find a program I want because the characters are so mixed up and so small that you can only guess what it is? How can I find such a station?
Why don’t I get the same channels delivered sorted as I have them arranged on the TV? Why can’t I find a channel by entering the TV channel at the top of the search function so that I can watch it? Why doesn’t Swisscom want to provide this service? I find it very weak!
Depending on the browser, the screen section can be enlarged.
Your own channel list can be selected to the right of the date.
At the top right there is the search function which then finds the desired program.
#user63
Hi, something like that
>“How can I find a station like that?”
>“Why can’t I find a channel by entering the TV channel at the top of the search function so that I can watch it?”
-> Enter the desired station in the search field and search. The “Channels” tab must be selected in the list below. In the example ‘SRF’, all SRF channels are displayed such as ‘SRF 1’, SRF 1 HD’, ‘SRF Info’, etc.
So it works wonderfully. It should be noted that not all channels are available on the web as they are on the box. The “transmitter convergence” is not (yet) 1:1 with the box. If a station cannot be found on the web, it probably does not exist on the web.
>“I almost never find a program I want because the characters are so mixed up and so small that you can only guess what it is”
-> Don’t understand what you mean by “wild mess” and “small”. For example, everything is easy to read on an iPad. The station is not always easy to identify based on the program logos alone. Maybe it’s also due to the screen setting (?).
>“Why don’t I receive the same channels sorted as I have them arranged on the TV?”
-> Under ‘TV Guide’ you can select the channel list that you created at home (or online). Normally there is the “Swisscom channel list” at the beginning, which shows everything like the “Swisscom channel list” on the box, including the channels that cannot be played on the web. If you want all web channels, select the appropriate “Channels on Web TV” list. The same settings also apply to the app.
Maybe it’s not the service that’s at issue here, but rather the operational difficulties. It doesn’t cost anything to ask…
Hello Orholam
Everything is very easy for you to use and appears to be recognizable! Not at all for me, I find it very weak on Swisscom’s part that they are not able to deliver a well-arranged and functioning program. I am very disappointed and find the service very weak!
This shouldn’t be an accusation but rather an insight based on what you said. It is and will always be the case that certain people have more trouble using any application/program than others. You will never be able to please everyone. That’s why there are great things like forums where people can be helped with questions and you can make suggestions. It is also important to ask the right questions. The point here is NOT to do something badly, but rather to provide hints/suggestions/workarounds on how things could be done better and to answer questions.
So if you say it is NOT easy for you to use and recognize, then please share what you think could be done better and how or what you don’t understand. Simply complaining serves no one here in the forum.
Even though the forum is hosted by Swisscom, the users here are mainly customers who exchange ideas. WE are NOT Swisscom!
Your questions have basically been answered. So what’s the problem here?
Why doesn’t Swisscom need the whole side of the screen?
Then they would also have more space?
I could make the font larger so I could see which channel I’m looking for?
Everything is so small and packed in this box! Why?
Today there are so many other good example sites that Swisscom programmers could easily use for guidance.
Why does the offer and prices constantly change, but Internet TV always remains poor!
> “Why doesn’t Swisscom need the whole side of the screen?”
At the beginning you have to agree on a size that best suits your needs and screen sizes, because nothing is more annoying than only seeing part of the content and having to constantly scroll back and forth. This means that the current default size fits even the smallest screen.
> “I could make the font bigger and that way I would be able to see which channel I’m looking for?”
Every browser today has a zoom function (in Silverlight’s example it should be IE [to 400%] or Mozilla [to 300%]): Settings -> Zoom. You can easily scale up the entire content of the page to the size that suits you.
> “Everything is so small and packed in this little box! Why?”
This was probably chosen in the design because it is compact and everything should be visible at a glance. But as I said, everything is a matter of taste. It’s normal that it suits one person better and others worse.
You will also find this compact design with all other providers (i.e. Teleboy, Zatoo, etc.).
> “There are so many other good example sites today…”
That would? Suggestions are always good when they are specific.
Hello Orholam, I can’t do it better! I can’t tell you how to make it better! But I can tell you and everyone else that I absolutely don’t like or like Swisscom’s entire Internet TV design! As I said, I find them confusing, not up-to-date and not comfortable or comfortable at all. I just wish for something better. That’s it!
It’s completely legitimate to say here in the forum that you like something or not. If you still have the why, it’s called constructive criticism. Otherwise this won’t help anyone, not even Swisscom. Then we’ll be curious to see how they’ll implement the design in the next web client.
In addition to all the pros and cons about the design, it would still be nice to know whether you could be helped “functionally”.
> “I could make the font bigger and that way I would be able to identify which channel I’m looking for?”
Every browser today has a zoom function (in the Silverlight example it should be IE [up to 400%] or Mozilla [up to 300%]): Settings -> Zoom. You can easily scale up the entire content of the page to the size that suits you.
Fortunately, those days are long gone. Today you can design a website so that it is displayed correctly on a wide variety of screen sizes… You can’t be serious about using the zoom function. Even if you can actually help yourself with this disaster website…
At least something new is supposed to come out in the summer and there is enough competition.
