Internet Box and Synology NAS
Hello everyone,
I bought a Synology NAS (DS215j). At home I have fiber optic Anschluss and therefore an Internet box. I haven’t had this for that long, as I moved in about 1.5 months ago and previously had a Centro Grande. Apparently all settings from the CG were transferred to the IB. So I didn’t have to set anything up for the internet. In addition, the Anschluss is in the fuse box in my apartment and from there I have to patch the sockets in the rooms.
Now I connected the NAS to a power outlet and the two hard drives were green and the status flashed orange. It was not found in the network via find.synology.com (don’t know by heart at the moment) or via the assistant. I turned off the firewall and antivirus on the Mac. If I attached the NAS directly to the notebook (MacBook Pro), it would be recognized, but that doesn’t help me. I want to configure this over the network. So I reset it and tried again. It just isn’t found. I’ve already tried installing the DSM via the local one and then assigning a fixed IP. After that I couldn’t connect to the IP either over the network or locally.
Do I have to set up something special on the Internet box so that the NAS can be recognized or found in the network? If I connect the notebook to the same cable and turn off the WiFi, I still have internet. So it can’t be due to the socket and cable…
Does anyone have an idea?
I’ve already read and tried various things here in the forum, but nothing has helped so far… I don’t know if it’s my Mac? Although then the network/LAN lamp on the NAS should at least light up?
