There can be many reasons for apps that don’t work, a lack of storage space or a low battery. However, we are often partly to blame because we ignore maintenance issues until it’s too late. And it’s actually not that hard to keep your smartphone in good shape.
Anyone who owns a car or a bike knows that vehicles require regular attention to keep them on the road. The same is true of smartphones – and yet mobile maintenance is often an alien concept. Here are some tips for improving the condition and service life of your device:
- Check for operating system and app updates regularly. Old versions can impair performance.
- Delete old data and apps on a regular basis, as unnecessary data can cause your phone to lag.
- Instead of deleting apps, empty the cache. On Android phones, go to Settings > Apps > All programs > Empty cache. On iPhones, apps are found under Settings > General > iPhone storage. If you then click on ‘Offload app’, it will free up the storage space used, but your data will be retained.
- Move your photos to a Cloud (e.g. myCloud or iCloud photos) and activate ‘Automatic backup’. Your pictures and videos are then sent straight to your online storage, and you can delete them from your mobile phone. This requires less storage, the system runs faster, and the photos are safe, even if something happens to your smartphone. You can also use your cloud storage to make a backup of your mobile phone (instructions for Android and Apple devices). It is best to always save your data twice, e.g. also locally on your computer.
- With a few tricks and the proper handling, you can keep your mobile battery in good shape when it’s charging.
- Cleaning is also part and parcel of maintenance. Keeping your mobile phone and case clean.
- The screen protector and case prevent minor knocks causing major damage, as well as stopping scratches and soiling.
Useful links
What regular steps do you take to keep your mobile running smoothly? Share your tips with the Community.
