Child and youth protection Only allow apps to be opened on Swisscom TV with a PIN.
  • When setting the 4-digit pin, the message “Unfortunately, this did not work. Please try again later. ”.
    Is it just me or do others have this problem?
    • roku73 has responded to this post.
    • aelch Have you tried it on the TV Box or in the blue Tv app?
      If you tried it on the TV box to no avail, try restarting it.
      If it still doesn’t work on the TV box, go to the Blue TV app, then to “More” at the bottom, and from there to the settings (cogwheel), then to Parental Controls, and try setting it there.
