Speed limited to 4g for multi-device SIMs?
Good morning,
I bought an HTC 5G hub modem.
When I put a Multi-Device SIM card in, I am in 4G and not 5G. In the same place, my iphone with the main card is on 5G.
I tried putting my main card in the modem, which went to 5G, then went back to 4G when I turned on the iPhone which usually hosts the main card.
Since then, it’s impossible to have 5G in the modem, even if you put the main card back in.
Is there a 4G limitation for Multi-Device cards?
