WiFi/password
  • Hello everyone
    I have a problem with my WiFi password.
    We have a Trixie TX8 Smart automatic feeder.
    Unfortunately, according to the manufacturer, it is not possible to pair the machine if the WLAN password contains special characters.
    This is a requirement of the Tuya platform, over which you unfortunately have no influence.
    Can I generate a Swisscom WiFi password without special characters?
    • @Danny1957 Workaround: buy a WLAN access point where it also works without special WLAN characters.
      Router -> Ethernet cable -> New WLAN access point without special WLAN characters ->Tuya automatic feeder.
    POGO 1104
    @Danny1957
    I used this TP-Link TL-WA801N for Fr. 28 from Digitec because of a case like this.
    It’s just 2.4G and LAN for 100Mbit/s, but in most simple cases it’s enough.
    It is also smaller and more inconspicuous with the TP Link Nano, configured as an AP:
    [https://www.digitec.ch/de/s1/product/tp-link-tl-wr802n-router-5615380](https://www.digitec.ch/de/s1/product/tp-link- tl-wr802n-router-5615380)
    You can hang it directly behind an Internet box and plug the USB cable for power directly into the Swisscom Internet box on the USB-Anschluss. In addition, of course, there is also the short LAN cable.
    By the way, all cables plus an additional separate transformer (if you want to plug it into a 230 volt socket) are included.
      @POGO 1104 wrote:
      @Danny1957 wrote:
      …..Can I generate a Swisscom WiFi password without special characters??
      It used to, but not anymore.
      Actually, Tuya has a duty to get up to date here…
      @POGO 1104
      Tuya is committed to being as simple as possible for the user and compatible with products/services worldwide. In the end, safety suffers.
