17 days later
Hello @Kionama34! Thank you for your message.
We would like to remind you to remain careful on forums and social networks. For your safety, only share your personal data in private messages. Please remove your phone number from this post.
Regarding your request, I invite you to click on this link: https://bit.ly/3H1IsO4, where our specialists are at your disposal to help you install your new Internet Box 4.
Have a good day
13 days later
5 days later
Hello everyone,
every time I receive an email that the IB-4 has been updated, my entire network crashes and I have to turn off my box, wait 1 minute and everything restarts…
And even today after a restart it is impossible to reach the login page.
It’s becoming really annoying with buggy updates!
@damien01
thanks for the contribution
>… every time I receive an email that the IB-4 has been updated, my entire network crashes and I have to turn off my box, wait 1 minute and everything restarts…. ..
it is better to not turn off the Internet-Box 4, but to logically restart it
to do this use the router management tool > Internet-Box > Restart> Restart the Internet-Box
How ​​can I change the Internet-Box settings?
You can easily manage the settings of your Internet-Box via the web portal. There you can change your WLAN access data, configure parental controls or view a list of all connected devices.
**On the computer
**In your Internet browser, enter http://internetbox.home or 192.168.1.1 Please note that access This is only possible if you are connected within the network with your Internet-Box. Then, log in with your existing admin login. If you don’t know the password, click “Set New Password” to create a new one.
**On smartphone
**Thanks to the Home App, you easily access the main settings from your smartphone at home and can to modify.
>… And even today after a restart it is impossible to reach the login page….
please specify the application concerned by the login page?
in addition the current version of the IB4 software package is 13.00.40, if this is not the case update it manually
Updating firmware on devices – Help | Swisscom
Version of currently installed software package
You can check the software version currently installed on your Internet-Box at any time by going to the web portal of the Internet-Box. Switch to “Expert” mode and, in the menu, click on “Internet-Box” > “Software”. Please note that access to the web portal is only possible if you are connected to the network with your Internet-Box.
Except that to do this you have to open and access the page 192.168.1.1 and it is impossible…
But since this morning everything is in order thank you!
5 months later
As a Swisscom customer, nothing is free, you pay a subscription of CHF 200.-/month for 20 years and when you change equipment you pay. For new customers offered, look for the error…….
I bought an internet box 4 which I returned after a week. The functions are identical to those of the internet box 3, apart from the USB port key, into which you can no longer connect an external drive, the USB port on the internet box 4 is only used to plug in a USB key for Internet reception in the event of a problem with the optical fiber. A function, in my opinion important, has been deleted, regrettable and incomprehensible
Hello Doremi,
Do I understand that from March 2023 the USB port of IB 3 will be disabled, i.e. the main memory option, see below, will no longer be available:
Central memory allows you to save documents, photos and videos centrally and access them from all devices on your network. To do this, connect a USB hard drive to your Internet-Box. To access your data, type \INTERNETBOX-NAS.home in your Windows Explorer or, if you are using a Mac, choose the “Shared” menu in Finder.Thank you for clarifying. Kind regards
3 months later
Good morning
Since I have the latest Swisscom box 4 router it works very very well even better than the old router I no longer have any problems.
plus the wifi goes very quickly to surf internet port the same thing, I very often update the router never any problems for the moment, I have internet connections at home which works very well.
I’m waiting for the new 5 generation box router from Swisscom to test, I don’t know when it will be released, thanks to Swisscom for the improvements which are doing the job well.
3 months later
I am a Swisscom customer with Raccordement Optical Fiber. I have Box 3 internet. Is it possible to use Box 4 internet? Are there any fees?
THANKS
Hello @owegen,
Box 4 is currently 99.- frs (Discount of 100.- frs)
[TO CLICK HERE.](https://www.swisscom.ch/fr/clients-prives/produits/internetrouter/details.html/internet-box-4-fibre-11050518?stch=plp&ing=ptl-device-first&simplyDigital=true&journey= device-first&contractDuration=24&useCase=HARDWAREONLY&payOption=ONE_TIME)
Cordialement, Prelude
