Thanks for the info. According to this page at Init7 the Fritzbox 5530 is only recommended for P2P, i.e. not P2MP (XGS-PON).
I also heard that XGS-PON connections cannot be ordered from any non-Swisscom provider at the moment.
There are complaints to the ComCo from some providers against Swisscom.
This thing seems to be getting complicated for XGS-PON customers.
Does anyone have more information about this? Greeting
@OdinTheGreat wrote:
I also heard that XGS-PON connections cannot currently be ordered from any non-Swisscom provider.
10 Gbit/s consumer connections in Switzerland are, afaik, always XGS-PON
At least at Salt there is 10Gbit internet and also at iway.ch (list is not exhaustive)
….keep on rockin'
@Stefan-zh wrote:
Hello everyone
Does anyone know whether the Fritz!Box 5530 now works on an XGS-PON? Got it today and set the VLAN ID to 10. But unfortunately no connection is established. She would have the certification.
Regardless of which router it is, you have a Swisscom Abo for your Anschluss, VLAN ID 10 is not enough anyway, then you also have to set up DHCP option 60 correctly.
You can find the values required for this here:
[https://www.swisscom.ch/de/privatkunden/hilfe/geraet/internet-router/ Fremdrouter.html?login&nevistokenconsume&error=NOT_LOGGED_IN ](https://www.swisscom.ch/de/privatkunden/hilfe/geraet/internet-router/ Fremdrouter.html?login&nevistokenconsume&error=NOT_LOGGED_IN)
Unfortunately you can only set the VLAN ID and the PBit, nothing more is possible.
I have now inserted { class_identifier = “100008,0001,AVM”; into etherencapcfg using the FBEditor.
But it doesn’t work either.
I assume that you would have to have the FRITZ!SFP XGS-PON module, but this is not included in the scope of delivery. However, only the AON and GPON module are included in the scope of delivery.
@Stefan-zh It’s not done with just an XS-GPON module; the driver for the XS-GPON module must also be present in the router. It is also very important that the module can communicate with the Huawei equipment.
According to publicly available information, the FB 5530 is certified by the BBF for XGS-PON, but not yet by Swisscom.
“SFP modules for XGS-PON, which are certified and approved for use in Switzerland, will be available later this year. ”
https://www.iway.ch/ueber-iway/blog/fritzbox-5530-neu/
@user109 wrote:
@Stefan-zh It’s not done with just an XS-GPON module, the driver for the XS-GPON module must also be present in the router. It is also very important that the module can communicate with the Huawei equipment.
Assume that AVM also delivers this. The IB3 wouldn’t be bad. Only I can no longer pair my Fritzen like this.
@Stefan-zh wrote:
@user109 wrote:
@Stefan-zh It’s not done with just an XS-GPON module, the driver for the XS-GPON module must still be present in the router. It is also very important that the module can communicate with the Huawei equipment.
@Stefan-zh with double NAT already 😉
And how do you do that specifically? Do you have instructions for that?
@Stefan-zh Uncle Google is your helper:
[https://avm.de/service/fritzbox/fritzbox-7590/wissenskatalog/publication/show/106\_FRITZ-Box-fur-Betrieb-mit-anderem-Router-einrichten/](https://avm.de /service/fritzbox/fritzbox-7590/knowledgebase/publication/show/106_FRITZ-Box-set-up-for-operation-with-another-router/)
