@Piongietzei94
Registration normally works via the link below and that would be the responsibility of the owner of the subscription!
A Swisscom login and password are required and this has nothing to do with the network, the subscription holder has this information.
https://www2.swisscom.ch/splashpage/guest/app/adsl_registration
In any case, this distribution is not the best because everyone can do what they want and somehow there is no control.
@Piongietzei94 wrote:
I pay 50 francs per month for it
For this Betrag you could buy your own internet… Maybe not from Swisscom (65.–) but from other providers. Might be a consideration.
Please focus on the questions above.
It’s basically pretty negligent on the part of the landlord. (legal point of view) If there is misuse of the Internet. But if a roommate has harmful devices, you can’t influence it and your Anschluss will always be blocked. Maybe take a look at who moved in last?
If a private Swisscom Abo is made publicly accessible, you must expect that the Internet connection will be blocked at any time. This mostly happens with email, spam and viruses. Swisscom is interested in ensuring that its Bluewin servers do not end up on block lists.
But if a repair is even necessary, this can only be done using the serial number or the Swisscom login of the connection. You tenants are unlikely to have that.
If we assume that the WLAN is not operated professionally, a blockage must be expected at any time.
If the WLAN is operated professionally, various technical measures are necessary, which are unlikely to be implemented as access with a Swisscom private customer subscription. Well, I wouldn’t do that, but there are plenty of weirdos on the market who might still come up with such an idea.
[https://www.li.admin.ch/sites/default/files/2018-02/Merkblatt%20WLAN.pdf](https://www.li.admin.ch/sites/default/files/2018- 02/Information sheet%20WLAN.pdf)
I would recommend that the landlord sets up something proper if he hasn’t already done so (radius, logging, proxy, etc.). Otherwise the Anschluss will be blocked again sooner or later.
Or as @Hitch hilft says, get a Anschluss yourself and disconnect from the landlord’s WiFi.
@WalterB: it’s not about registration, but about activation. Is it normal that registration is required for activation? The Internet is already registered and I am active on the Internet. Why doesn’t it just show that the password is incorrect?
@Hitch hilft: the situation is comparable to that in a large shared apartment. People move in and out there, other people spend the night there, WiFi is shared, etc. I don’t have my own Anschluss in my room from which I could get internet (no own landline telephone connection, TV connection also shared, etc .). I’m waiting for wireless options to become available. I saw something like that last year (Sunrise?), but it didn’t seem to work reliably. Presumably this will only really be possible with 5G? But that doesn’t change my rental agreement. I would then simply have to pay twice.
The internet has been massively disrupted for a year and the landlord hasn’t done anything for months. Often I can’t get internet even though I’m connected to WiFi. I suspect someone else has/had a device that uses the entire bandwidth of the WLAN. However, a yellow triangle often appears, which seems to indicate a Swisscom problem (at least it was there all the time when a frustrated fellow tenant damaged the cable socket, and it also appeared again yesterday and today when I started the computer in the morning). It was good for a few weeks recently, but now this lockdown. If the problems are not caused by co-tenants, then by Swisscom (it is certainly not in Swisscom’s interest to block Kaspersky). Apart from the landlord, no one knows who moved in last, and they don’t care about internet problems. He’s not on the network himself. He certainly won’t set up another, more complicated WLAN, @Tux0ne He simply took it over from the previous owner unchanged (the name of the WLAN is still the company name of the previous owner, and the password is also the same as in 2008) .
The question again: are the same websites also blocked for the landlord on his own device when he comes here? Otherwise he won’t see the access blocked message and won’t be able to activate it.
Yes, don’t worry. The Internet is now closed to everyone and anyone who wants to surf comes to the splash page.
@Piongietzei94
I understand the situation on site. You simply cannot work around the problem with this existing solution.
Another variant: You could of course also get a mobile subscription (for 50.–) from a provider. And get an LTE router. e.g. Huawei and insert the SIM card there. Afterwards you have your own WiFi etc. also for the 50.–
Of course it would be an advantage if you had 4G in the apartment.
Thanks, @Hitch hilft Wouldn’t the amount of data or speed be limited with a mobile subscription at this price today? Otherwise, I could theoretically use a smartphone as a hotspot (I think, although probably not entirely permitted), but I need unrestricted, high-speed internet access. With 5G, this will probably be possible next year or the year after, right?
Thank you, @Tux0ne I sent the landlord an email with screenshots and details of websites that were blocked for me, asking him to unblock the internet.
Is there any information from Swisscom about these internet blocks (especially the causes and how they can be prevented) that I could send to the landlord (with the request that it be forwarded to the other tenants)? I can only find posts about this in the community forum, but nothing “official”.
I still have to ask again now. Only a few sites are blocked?
Unfortunately, too much has already been written that I just read across 😄
Can you post a screenshot of the lock page?
Because you have to differentiate between complete blocking, blocking by Swisscom’s DNS Guard or even another blocking of a 3rd party product.
    I don’t know if there is an official “brochure” or something like that.
    But the situation is actually explained quite quickly: As soon as one of the (numerous and changing) users catches a malware on their computer, for example, which then starts sending SPAM or something similar, the Anschluss is blocked for ALL users.
    This can hardly be avoided with the way this Anschluss is now operated (which is not really “intended”), unless you are lucky enough that all users always stay clean…
    When it occurs for the first time, the whole thing can be unlocked relatively easily. However, only for the connection owner, i.e. not for you tenants, who probably don’t know the corresponding Kundencenter access data (not the same WiFi access data!) anyway.
    If this happens again, this will also become more complicated for the landlord, because Swisscom only initially accepts an assurance from the customer that everything is now OK. If, despite such assurances, abuses continue to occur, people will soon want to know more precisely what measures have been taken.
    In short: For this type of use, a more professional WLAN system would actually be appropriate, in which the individual user can be identified. Of course, it costs a little more than simply installing a Swisscom home customer router and then passing on the subscription x times over to your subtenants.
    @Tux0ne
    This is probably the normal connection blocking that we are assuming here.
    I have noticed on several occasions in the past that the blocking process is sometimes not “clean” (i.e. some pages work, some don’t).
    I’ve already asked a Swisscommer about why this is the case. Of course he didn’t know how to stammer much. Maybe their locking mechanism just doesn’t work properly 😉
    Incidentally, we can also safely assume that the WLAN here is operated “non-professionally” (according to BÜPF terminology). This will simply be some homeowner who has earned a golden nose by taking out some Vivo Casa subscription and now “subletting” it. (I think even if a “professional” had told him that, it still wouldn’t count as a professional business. The law seems pretty “tame” to me. In the end, this only affects “external” operators à la Monzoon, So probably not even the electrician/networker who sets up a public WiFi in the restaurant, unless he then operates it centrally.)
    @Piongietzei94
    In order to completely decouple yourself from the owner, here is another example of an unlimited LTE high-speed Anschluss (available from various providers, but probably not from Swisscom):
    [https://www.sunrise.ch/de/privatkunden/mobil-abos/mobile-internet/hotspots/hotspots-fuer-zuhause.html](https://www.sunrise.ch/de/privatkunden/mobil- abos/mobile-internet/hotspots/hotspots-fuer-zuhause.html)
    With such offers, it is of course crucial to check beforehand whether the respective mobile network has enough power at the desired location. By the way, good 4G is more than enough, waiting for a not yet fully developed 5G is absolutely unnecessary.
    Tux0ne, yes, just a few individual pages. I’m here on the internet now. Here is the screenshot:
    @cslu, there have been no problems with the Internet for 10 years. It has been constantly malfunctioning since August 2018. It also seems to me that the problems that have been going on for a year are at least partly caused by Swisscom. I say again: why is Kaspersky blocked (as one of very few sites)? There is no logical explanation for this. If Kaspersky wasn’t blocked, I would probably just leave the block as it is and work around it to avoid another level of escalation with further blocking. Of course, this is not possible if Swisscom blocks the anti-virus software. The problem here is partly caused by Swisscom, as there is currently no full protection (and until the landlord takes action).
    There are different locks, as @Tux0ne already mentioned.
    1. Internet Guard
    Internet Guard blocks sites that are classified as “dangerous”, the reasons for this are usually phishing, drive-by infections or similar. All other pages can be accessed.
    2. Blocked due to spam/botnet
    If the Anschluss is blocked because a client sends spam or botnet traffic is detected, then you will be put in a sandbox. A sandbox only allows access to certain pages. This also includes antivirus manufacturers.
    However, since the sandbox must maintain a list of domains and/or IP addresses of the websites, it may well happen that certain sites such as Kaspersky can no longer be accessed if the domain or IP address of Kaspersky’s web server changes. Swisscom should take note of this and update the sandbox.
    It’s relatively easy to get out of the sandbox twice, but things get more complicated the third time.
    3. Suspension due to unpaid invoices
    As far as I know, there is also a block/sandbox if invoices have not been paid, everything is then blocked, i.e. no internet access and you are redirected to a page which informs you that there are still outstanding invoices. (I’ve never seen these personally…)
    4. “Block” at new Anschluss
    With a new Anschluss you are also in a sandbox. However, this redirects all requests to a registration page. However, this should only be activated for new or not yet initialized connections.
    Basically, you as a tenant are powerless.
    The landlord can unlock the Anschluss, but if one of the roommates accesses the WiFi again with a “contaminated” device, then the Anschluss will be blocked again and the whole thing starts again.
    If I were you, I would use your cell phone as a hotspot. Depending on where you live, this should be possible without any problems with your current subscription. The subscription should simply not be throttled (speed) and should not have a limited data volume. I do this all the time with my cell phone, but it may work better in the city than in the country…
    @gasoo, I just posted a screenshot (our posts overlapped). I currently have a 3G prepaid cell phone that I hardly ever use. I would have to get a smartphone first, but I don’t really want one (for various reasons). What I saw last year was a mobile hotspot (I think from Sunrise) that was/was marketed as a solution for outdoors (e.g. when camping). It should actually work indoors too. But the reviews and customer ratings really weren’t convincing. Not a problem if it’s only used occasionally, but probably not suitable for long-term use (yet) (probably what @Werner linked). As far as I know, you can also be blocked by providers if you use your smartphone as a hotspot. I really need the computer a lot. That would probably be noticeable.
    We are more rural here.
    As I said: It’s not clear to me why it’s only blocked “selectively” or, in my experience, it’s not always like that.
    I once explicitly asked a Swisscom employee this. At first he didn’t really want to think of anything to say about it, but in the end he said that the first escalation stage wasn’t about blocking everything completely, but rather just making the customer aware that there was a need for action.
    Whether it makes sense to block Kaspersy here remains to be seen… although I wouldn’t put too much trust in the snake oil mafia 😉
    Regarding your derivation in the last sentence: I understand what you mean, but
    - The infection obviously took place before the lockdown, i.e. cause and effect should not be mixed up chronologically.
    - There can be no talk of “full protection” anyway. Beating oil is 95% marketing and 5% effectiveness.
    And last but not least: The fact that the Internet ran smoothly for 10 years under such “conditions” may also have been due to a bit of luck. Maybe Swisscom is blocking more aggressively these days than before, I can’t say that with certainty.
    In any case, Swisscom has always vehemently denied the fact that there are cases in which blocks are blocked “for no reason”. Especially in a case like the one at hand, we have to assume that there is a cause in one of your “roommates”.
    But… apart from asking the landlord (or getting “independent” internet) there’s not much you can do. 4G broadband routers work if you have reasonably good reception at the location and are not in a completely overloaded radio cell.
    @Piongietzei94 I have a Swisscom Abo and use a second SIM in my laptop, both on the same subscription. That’s why I’m constantly on the internet on my laptop via my cell phone. When I didn’t have that yet, like 3 years ago, I often connected my laptop via cell phone hotspot, watched YouTube, installed updates, downloaded large files and sometimes even via torrent. Never had any problems, even though there were several Giga together.
    Speed ​​and stability of course depend heavily on the existing antenna…
    @cslu, what I meant was that I didn’t have an infection (at least not one that could be detected by Kaspersky, Malwarebytes or Windows Defender). May be different for one of my fellow tenants. But until this is sorted out, I can no longer download Kaspersky updates. This means there is a risk that my computer will also catch viruses that were not there at the time of the partial blocking. That would then clearly be Swisscom’s fault.
    @Piongietzei94
    If you want to solve the Kaspersky problem in the short term, just throw it out, because the Defender that is already built into Windows 10 has just won the latest AV test.
    In the medium term, perhaps switching to a “home-capable” LTE router would probably be the best solution for you if the reception is good (by the way, Sunrise’s home hotspot is actually unlimited according to the fair use policy, since it is actually for you home connection is provided)
    @Piongietzei94
    Can you access the Kaspersky website or is that not possible?
    When you do the updates, do you start them via Kaspersky software?
    If there is a new domain for Kaspersky, you could forward it to the appropriate authorities.
    To do this, you would have to know what exactly is being blocked.
    Thanks, @Werner, good to know that Windows Defender could be enough if the landlord doesn’t act or it can’t be determined which co-tenant has the problem. Is it possible that the Sunrise WiFi Tower & Mobile Internet offers better performance than it did 12-18 months ago when I last looked at it? Reads well. Thanks for the tip. I am a Sunrise prepaid customer myself (but only 3G). According to the Sunrise network coverage tool, we have “super-fast mobile internet”, albeit outdoors. It is a 500-year-old house with thick walls, in a historic town, surrounded by other such houses. Can this make a difference to how good the reception is inside the Sunrise WiFi Tower & Mobile Internet?
    @gasoo, extremely strange: kaspersky.com, kaspersky.co.uk, kaspersky.de, www.kaspersky.com, www.kaspersky. co.uk and www.kaspersky.de all land on the Swisscom block page. However, if I search Kaspersky on Google and click on a result for https://www.kaspersky.com/, I will go to https://www.kaspersky .de/ redirected, not to the blocking page. If I enter https in the browser, I also go directly to https://www.kaspersky.com
    To rule out the possibility that it is a virus that is blocking Kaspersky, I just tried this with another site that is blocked by Swisscom. When I try to access spiegel.de or www.spiegel.de (the German news magazine) in the browser, the site is blocked by Swisscom. When I click on a Google result for https://www.spiegel.de, I am redirected to the Spiegel page. Then when I click on an article it doesn’t block either. If I enter https://www.spiegel.de directly in the browser, I get to the correct page, not the Swisscom blocking message.
    So it seems that https URLs work. Is it possible that Kaspersky updates come from a URL that is not https?
    Updates occur automatically. I now only get a message every 20 minutes that the update failed.
    @Piongietzei94
    The thickness of walls and the exact location obviously play a role in LTE reception.
    However, this can be tested very well in practice with a 4G cell phone and the SIM card from the right mobile network (perhaps you have a colleague who can try it out for you in your apartment).
    The LTE routers have also gotten better recently, but I don’t specifically know the device included in the linked offer.
    At least it does say that the antennas can also be connected externally - if you have a specific need and interest, you would probably have to do more research yourself.
