@meli2 wrote:
So,
1. Internet Booster it is not DSL
Okay, there are problems with the device at the moment.
2. I think so, the house installation was done by the electrician…what should he pay attention to?
He should have a new cable U72M 1×2×0.5 from the telephone junction box (UP) of the house to the junction box
of your router.
3. with an Ethernet cable
Good connection solution.
4. Centro Business 2.0
Okay
I hope I could help you…
Have you restarted the TV-Box and the router? If yes, change?
Otherwise, call 0800 800 800 for private customers or 0800 055 055 for SME customers.
Request an error measurement of your DSL connection and ask for measurement data from the Datamat program because of your TV-Box.
The disruptions can come from too little bandwidth on your Internet Anschluss.
Hence the measurement at support
