Recordings Downloads not visible abroad if there is no network
The downloaded recordings seem to me to be designed to be viewed offline, and are downloaded to the tablet.
Abroad, if there is no collegamento online, the program does not open, the symbol always remains spinning.
Therefore they are not usable. The application should always open, with the menus available, then if there is no network some functions are deactivated
