Then you have DSL and NATEL Pro as a product or simply an Infinity and no telephone?
These are technically 2 different things.
In principle, A: Vectoring or g.fast is not yet activated.
B: The router firmware cannot benefit from this.
If you want, you can send me the Anschluss or phone number as a PM. I would like to take a look at a shaft like that 🙂
We now have Fiber to the street in our neighborhood. The number checker now gives me 60/15 as the maximum.
I would like to order Vivo M 50/10. What is the best way to find out whether my Anschluss actually gives this value? I would like to clarify this in advance and not generate pointless visits from technicians.
Thanks for the reply
I have a Fritzbox 7490, vectoring is now also possible.
By the way, it is activated, I have the information under G.Vector full.
My consideration is whether the information on the line checker is correct. That’s my experience with it.
Ask the 2nd level support (BBCS) they can query your house connection if several SC customers are connected there. They could tell you about how much speed to expect.
Line capacity is shown as approx. 83000/14000. The values ​​always fluctuate somewhat.
Failure margin is 28/17
Line attenuation ⅞
Are the fluctuations in line capacity normal? The values ​​fluctuate between 83,000 and 85,000
The line capacitance is only a theoretical value and says nothing about the actual switched speed. It is normal for this value to fluctuate.
If the “Current data rate” is higher than 50000/10000 you get the full speed at Vivo M.
Hallo
| Measurements |
| Transmission speed | Upstream: | 0 Kbps |
| | Downstream: | 0 Kbps |
| Line attenuation | Upstream: | 3.7 dB |
| | Downstream: | 3.4 dB |
| Signal-to-noise ratio | Upstream: | 12.3 dB |
| | Downstream: | 21.4 dB |
Sorry, had an early shift.
Where can I read this data at Centro Grande?
PS: Speed ​​measurement at Ookla at the moment
20.25Mbps down
2.20Mbps up
Wow!! Thank you
Hello
If the values ​​remain that way, I would politely say thank you for your competent help.
I will definitely recommend this forum.
That’s how it’s fun.
If everything goes well, I will close this issue and accept it as a solution.
Thank you again!!!
@WarmRed
Basically your line looks good.
You definitely don’t have a Bridgetap.
But: There is still a small hump at the back of the carrier 3584, so the values ​​go up again.
Because of the 9dB signal-to-noise margin of the good values ​​in the upstream and this bump, I suspect that other lines are interfering with your line and that a different line would add a few more Mbits.
What speed does the checker show? www.swisscom.ch/checker?
