Netgear RS300 - connected once for 10 minutes and then stopped working
Hello
I was able to setup my new router to connect directly to the internet (copper). DHCP Option 60 setup, everything fine. It worked for 10 minutes, then I lost the connection to the internet. When I connect the IB2 back, it works just fine.
After calling the support, they told me they “see an error, non-swisscom router plugged-in” so they disable the port.
They resetted the port, I tried to clone the MAC of my IB2 but zero, nothing.
According to the PAID support (very useless btw) my settings are correct but… swisscom does not support 3rd party routers.
RN I’m using the RS300 as an AP connected to the IB2 which is not optimal.
Any idea what should I do?
Thanks!
PS: I saw the other topic related to a similar issue, but I think this one is different because it worked for around 10 mins.
