Problem with "change channel" button
Since the introduction of compulsory advertising, I can often no longer switch back to the previous channel using the "Change channel" button with the TV-Box remote control. When pressed there is often no action (3x out of 4x doesn't work). The batteries in the remote are new and the box/router restarted. Does anyone have an idea?
