Hi all,
My home set-up is the following: 500 Mbps speed with Internet Box 4 in the basement connected via Cat 6A cable to 2 WLAN Box 2's on the ground floor and 1st floor. The wireless speed with the ground floor WLAN box is fine, close to 500 Mbps. However, the 1st floor wireless speed is only 100 Mbps or less. If I connect my PC directly to the 1st floor ethernet, it returns to 500 Mbps but if I connect the PC with ethernet through the WLAN Box, it goes back to 100 Mbps. So, there is no issue with the ethernet speed at the wall, but the WLAN Box seems to slow it down, whether it is wired or wireless.
Any ideas? Thanks.
Paddy Gregory
