Hello @Pharao
Thank you very much, so you now get 5.1 in Dolby Digital Plus from the TV box.
So you now have surround sound.
That’s fine if you’re on SRF1.
If you now go to SRF info you still have DD+ 5.1 where the station only sends stereo and there is also a bug here and we output this 2.0 signal from SRF info as 5.1 where only R and L are used and C, Rs and Ls are empty or carry no signal.
This means that with SRF info or all stations that broadcast in stereo/2.0 you only hear something from R and L.
But we fixed this with a software update.
You can get all channels that broadcast in 5.1 as normal. although SRF 1 mostly only uses the C for the Tagesschau.
Hope this helps a little.
