DSL over cable directly to UDM
Good morning, I read online that it is possible to configure the Ubiquiti Dream Machine router in such a way that the Swisscom router is no longer needed. Is this correct? Do you need special adapters / accessories or is it sufficient to connect the WAN cable (RJ45) directly to the dedicated UDM sockets?
You also need to configure the port:
- DHCP Option 60 (100008,0001)
do we need to do anything else? Thank you
