I just wanted to quickly explain why the time report thing actually bothers me so much.
The Swisscom Assistant displays the incomprehensible message in a window that cannot be moved or placed in the background. You can partially view other windows if you look around the Swisscom Assistant window. The Swisscom Assistant wants to tell you: I am important.
And if you then choose the actions Fix or Close, then nothing happens - there is no confirmation message, nothing. This is poorly designed, poorly programmed. Swisscom Assistant: zero points.
@Chaziosse19
For my opinion on the assistant, see post #2
In addition, without an assistant but with some interest in the matter, over time you will achieve a certain level of ICT know-how that everyone should have these days.
@all
I’m just dreading the fact that I’m going to have to join the queue on 0800 800 800 and explain EVERYTHING I’ve learned from you so far. Sigh…
Does the Swisscom customer phone actually not keep track of what’s going on in the community discussions?
@Chaziosse19
You can also request a callback in this way:
https://www.swisscom.ch/de/privatkunden/hilfe/kontakt.html
Or you can report the problem via the chat bot SAM, which will probably not understand you and then hand the chat over to a support employee.
Or you fill out the contact form, where you can also upload a screenshot of the error message, then you don’t have to explain much:
Contact form | Swisscom
P.S.:
Swisscom employees also read here, but it is not the official channel for fault reports.
Swisscom customer service (I ended up at My Service most recently) recommended that I reinstall My Swisscom Assistant yesterday. Today it was also suggested to me to synchronize the time manually (which I think would only be a temporary symptom relief).
Then I was informed on the phone that further clarifications/support from Swisscom My Service would be subject to a charge.
We therefore agreed that I would either (a) look for a setting in My Swisscom Assistant to switch off such notifications, or (b) uninstall the My Swisscom Assistant or © simply ignore the warning message about the time would.
Just to conclude: the message about the “wrong” time always appears if I don’t have an internet connection when I start the PC. But that would still not be a reason for me to send myself a false error message…
This closes the case for me. Thanks to all the helpers involved
@Chaziosse19
What time does the clock show before the PC is connected to the Internet?
Your clock may actually deviate too much before it is synchronized via the Internet by the NTP server. In this case the error message would be logical and correct.
@hed
Determined with the time-DOS command without an internet connection: My PC differs from the radio clock on my wall by a maximum of about 2 seconds. This precision is enough for me for an offline connection. I don’t do high-frequency stock trading.
The Swisscom assistant can’t know any better offline and should therefore refrain from complaining.
4 months later
Thanks for the reaction selection for the time reports. I can simply click away these unnecessary messages. Now that I know the reason for the message, it doesn’t bother me much anymore. I will therefore take no further action in this regard.
  • hed likes that.
At my home on the farm, if the walking board was wrong on the way to the manure heap, they always put it in the right place so that the manure hen didn’t flood too early every time.
Applied to our case: I would like the apps to also fix problems that may not be vital, but are annoying and simply unnecessary.
Every programming language has simple constructions to do something (necessary) or not do something (unnecessary) depending on a condition:
if (_online) then
do; /* the necessary */ end;
else /* if offline, then leave it */;
If the application programming department doesn’t have time to fix even small errors, then something is wrong.
