Internet-Booster 5G: Speed prüfen, bestellen und schneller surfen
I have the Internet Box 2, which is relatively thick, not the newest 3. On the balcony I have real 5G reception with around 400 Mbit/s download from Glarus Bergli. The very good antennas should also offer me reception of real 5G on the inside of the window
An inquiry to Swisscom revealed that the booster must be connected directly to the router. When I read the comments here, it sometimes sounds as if this can also be installed on a switch in the network. The router is in my basement, I have a switch by the window.
@Tiosch6712
It can also be done via a switch, but VLAN ID 699 and 700 must be tagged. If it is a smart managed switch, you can set that.
The switches from Swisscom (TP-Link) are already programmed accordingly.
A run-of-the-mill switch from the electronics store usually can’t do it
….keep on rockin' 🤘🏼🤘🏼🤘🏼
Thanks for the tips. Then it will be like Swisscom TV. This doesn’t work with all switches either. Netgear works for me on Swiccom TV. I’ll try that.
The Netgear Switch GS105E is afaik not configured for the 5G Booster. Since it is a smart managed switch, you can program the VLAN ID 699 and 700 accordingly.
I have 12.02.xx as firmware and 70/20mbit copper. But I don’t see anything with the booster anywhere during the check. 5G antenna is 300 meters away and available on the phone.
@hed @Alex
I’ve had good experiences with the mobile phone in finding the best signal in the apartment and if you have reception it’s the signal from Swisscom.
There will sometimes be a problem when there is snow or the trees have leaves again, you notice this very well with the reception quality “dBm” on the 5G booster.
If you want to clarify this before buying a booster, then you will definitely need a 5G cell phone.
Sure, there is a right of return, but not everyone wants to go to the trouble.
🙄… sure. You’re right. I interpreted @Alex’s post to mean that he already has a 5G cell phone… It was just intended as a hint that the booster has a built-in help for finding and aligning it best reception…
a month later
This evening it was mentioned in the SRF news that the existing 5G mobile antennas will be allowed to increase their performance from January 1st, 2022, but the opponents have already announced resistance.
The link below explains what exactly happens during this performance adjustment, which takes a maximum of 6 minutes. may take place.
[https://www.bafu.admin.ch/bafu/de/home/themen/recht/mitigungen.msg-id-86469.html](https://www.bafu.admin.ch/bafu/de/ home/topics/law/communications.msg-id-86469.html)
So that this is only possible for a short time, adaptive antennas must be equipped with an automatic power limitation. This ensures that the transmission power used for the calculation, averaged over a period of 6 minutes, is not exceeded. This technical measure is the prerequisite for the application of the correction factor.
