thanks for the contribution
Help Apple Support
Switch from Android to iPhone, iPad or iPod touch - Apple Support (CH)
FAQ WhatsApp
WhatsApp Help Section - Restore Chat History
Well, I already had the first link open, but after the transfer, after entering the Apple ID, etc. there is still a selection regarding apps, but nothing happened when I tapped on the top selection from Android. It also didn’t take over any email accounts and I had to set everything up myself. When it comes to technology, I’m anything but a borrower and I’m familiar with the subject. I was just annoyed that it didn’t work.
Regarding the times link, it describes restoring to Android or Google Drive. only this is not possible on the iPhone because it only shows iCloud. I’ve almost resigned myself to the fact that it’s probably gone… maybe I can still save it with the PC version… let’s see
- Solutionselected by RaphaelG
Regarding WhatsApp, there was a demo version where you had to connect both devices (Android and iPhone), but you couldn’t convert all chats and messages over. otherwise you would have had to buy it.. January I live with it 😅
I downloaded the other apps again from the app store. I also set up mail accounts myself (GMX was the most annoying because when I set it up automatically it always came up with POP instead of IMAP… but if you enter the wrong PW, you can set it up manually).
