- Solutionselected by YariB
You can also change the recording time in the settings of your Swisscom TV - much easier via blue TV on the web on your PC or tablet: [https://tv.blue.ch/account](https://tv.blue.ch/ accounts).
Log in with the same Swisscom login linked to your TV subscription.
Here you can set the recording time:
I hope I can help you.
Dominik
Dominik
to close a topic by the initiator, if the problem has been resolved or no longer occurs
please accept the post @DomiP as an approved solution
for this use the Solution? option at the bottom left of the post
Is the answer a solution to your contribution? Then indicate it as a solution
or use the equivalent option with the cogwheel at the top right of the post
