E-mails received
  • Good day
    I use windows live mail and the mail program on my new laptop. The inboxes in the mail program are lost after the emails are opened. How can I set the program to keep these emails saved?
    Windows live mail everything works perfectly. All emails exist.
    Imaps activated for mail, junk emails remain saved.
    • Windows Live Mail is totally outdated, insecure and is no longer maintained by Microsoft.
      You should no longer use this program.
      Switch to the new “Mail” program that is already included in Windows 10 or, if you want an alternative to Microsoft, to the “Thunderbird” program, which can be downloaded for free from the Internet.
      With these two current programs, creating mailboxes is very easy because you only need to know your email address and mailbox password; the rest of the configuration is done automatically.
    @Scheschievi24
    If IMAP is set, the mail should remain on the WEB server, or there is something set in the email program that deletes the mail from the server.
    [https://praxistipps.chip.de/imap-und-pop3-das-sind-die-differente\_11773](https://praxistipps.chip.de/imap-und-pop3-das-sind-die- differences_11773)
    Hello Werner, that’s not entirely true with the synchronization in Thunderbird
    For example, contacts are not automatically synchronized, but Windows 10 Mail is
    @Befronef87 wrote:
    hello Werner, that’s not entirely true with the synchronization in Thunderbird
    e.g. contacts are not automatically synchronized, but Windows 10 Mail is
    For example, if you are talking about Google contacts (Bluewin contacts cannot be synchronized anywhere), in Thunderbird, unlike W10 Mail, you simply need to install an additional add-on.
    • WalterB has responded to this post.
      Werner
      @Befronef87
      Synchronizing with contacts and calendar, for example With iCloud works great, as already mentioned, install the appropriate AddOne, see picture below.
      This then works across all systems, be it Windows, MAC and Linux.
