That will probably be the reason, see link below.
You can also report it to support and mention that it works with a foreign DNS.
https://www.swisscom.ch/de/privatkunden/hilfe/internet/internetguard.html
Notification below if a page has been blocked unjustifiably.
https://www.swisscom.ch/de/privatkunden/hilfe/internet/internetguard/formular.html
@WalterB what makes you think TIDAL is blocked by Internet Guard?
If the domain were blocked, nothing could be played, but if I see it correctly, the streams can certainly be played, although with poor performance.
I don’t have TIDAL and can’t understand which domains are involved.
If anyone has experience with tcpdump or Wireshark and can check which domains are involved, I may be able to help.
Ok, maybe that was the wrong assumption. At least it works with the foreign DNS, so it has to be reported to Swisscom.
There have been cases here where the guard slowed down the opening of pages, unfortunately I can’t find the thread here in the community at the moment.
Hello everyone;
Simply change DNS1 to 8.8.8.8 and DNS2 to 8.8.4.4 (these are the Google DNS servers).
That solved the problem for me too. Then restarted the router.
Swisscom hotline helped me with this, thanks again to everyone.
Streaming Tidal Masters works again; but internetguard is out of service.
So you have the choice of either tidal or internetguard.
@Vabiezaus82 wrote:
Hello everyone;
If you want to use a non-Swisscom DNS that, unlike Google, still has a malware protection filter, my recommendation would be the Quad9:
DNS1 = 9.9.9.9
DNS2 = 149,112,112,112
Works very well in practical use and never has any failures due to its international network design.
@enrAArne Thank you, that confirms my suspicion.
On the two DNS 195.186.1.162 and 4.162 the following IP is used for tidal.map.fastly.net. issued:
;; ANSWER SECTION:
tidal.map.fastly.net. 30 IN A 151.101.38.142
At 195.186.1.110 and 4.110, as well as on Google or others, for tidal.map.fastly.net. the following IP output:
;; ANSWER SECTION:
tidal.map.fastly.net. 29 IN A 151.101.114.142
(Sometimes also 151.101.14.142)
I just assume that this is the CDN domain, but I don’t know for sure.
The response times of 151.101.38.142 are twice as high for me as for the other IP.
Since the two.110 DNS are in a different subnet, they receive a different IP from fastly.net.
I guess the CDN mapping isn’t optimal, I’ll ask if that’s the case.
Hello everyone
Unfortunately I only got to the next step today.
I manually configured the DNS on my Swisscom router to 8.8.8.8 and 8.8.4.4. Since then, my devices (see below) have been working perfectly again, which means streaming from Tidal is possible again without interruption.
Devices used:
Apple iphone 6s plus
Apple ipad pro (3rd generation)
AVM MP 5.2 CD/Media Player
Hope it works for everyone else too.
Greeting
I had been in contact with Tidal for weeks about this, reinstalled the software, tried everything because the pieces kept breaking off, in Roon with “Tidal content loading slowly”, in Tidal itself without an error message.
I had thought the problem was with Tidal. I was a little puzzled by the fact that Tidal works via iPhone and cell phone network, but not in WiFi. A colleague gave me the tip that it could be Swisscom.
While googling I immediately came across this thread, logged in to 192.168.1.1, entered the Google servers instead of the normal Swisscom DNS servers, and voila, it’s up and running again ;-)
Thank you so much, kind regards
Kurt
Quick update, unfortunately fastly.net didn’t respond.
However, the same IP addresses as Google and .110/.111 are now returned in the DNS response on both DNS 195.186.1.162 and 195.186.4.162.
So in my opinion TIDAL should work again with the .162 DNS.
If that’s not the case, it wasn’t due to this mapping.
