Installing OS 3.2 update. is imminent. All customers should actually receive it in May.
You can find complete information on this Community post https://bit.ly/2vTJKqP
Good day
Good day
Some struggling people have contacted me to ask me how to activate the dark display which is much more readable than the light display.
So here is the procedure to follow:
Press the Home A button on your remote control
Move to Recordings by pressing D
Press F to move to the gear Settings
Press the OK C key
Go down to Appearance by pressing E as many times as necessary
Press the OK C key
Go down to Dark display by pressing E
Press the OK C key to Save the Dark Display
Quickly check by pressing the TV Guide B button
Good luck!
I confirm that this version of the Swisscom TV firmware brings almost nothing from a functional point of view but above all regressions concerning the reliability of the remote control connectivity. It is now almost daily that it flashes red because it has lost the link with the box. It comes back after a few seconds… but extremely painful.
Oh sorry… You’re right.
I read too fast and read EOS instead of iOS…
However, the previous messages made me think of EOS since it is (if I understood correctly) the Swissco TV Box.
I simply wanted to say that my Swisscom TV Box (since we are talking about Swisscom TV-Box) is already running on EOS 4.0.
