Questions about the return function and data rates Swisscom TV 2.0
I have 2 technical questions regarding SCTV 2.0 with UHD box. I’m not a subscriber yet. Is it possible to jump back on live TV? So if, for example, I don’t understand a passage in a crime novel or want to see a goal again immediately, can I jump back? Or is this only possible in REplay and recordings? Until now I had satellite TV with a hard drive and then you could always jump back up to a maximum of 30 minutes.
And now something important since I have a large TV: What data rates does Swisscom use to broadcast in HD? Sunrise has 7 MB/s. How is it at Swisscom? That also needs to be compressed and converted here is clear because IPTV. Because I also value good image quality. IPTV is not considered a picture miracle because of the conversion and compression. But today things may look different. The technology and experience of compression etc. is now further advanced than it was 3 years ago.
What is the data rate for replay and recording? With SUnrise TV it is constant everywhere. Therefore no waste in replays or recordings or purchase offers.
I thank you for your tips.
