Configuration Switch Netgear GS108Ev2
Good morning.
I bought a Netgear GS108Ev2 switch in a Swisscom Shop and plugged it in without configuring anything. Everything seems to work well except that sometimes when I watch a Riplay program or sports on the channels in the Teleclub Sports package, the image becomes pixelated at times and some image jumps occur randomly.
I don’t know if it’s related to the switch or it’s a problem in general on my line.
It’s not too bothersome since it’s not used too often, I would still like to be sure that everything is properly configured and set.
I have my entire apartment wired with RJ45 cat.6 and I couldn’t try to connect directly to the internet box without going through the switch.
On the other hand, for those who have the same switch, have you configured it in a particular way?
I would like to be sure that it is properly configured before moving all my furniture and unplugging all the cables to try direct connection.
Thank you for your answers.
