Thank you so much.
I reset the router and set the config for the WLAN.
We will see if the situation improves.
Otherwise, how should I get the internet box?
THANKS
Okay thank you.
Another battery disconnection 1 day after resetting my router.
Is it possible for the router to restart automatically every 24 hours?
THANKS
Yes, I already tried several months ago but it didn’t change anything.
I’m going to call the hotline to see what the problem is.
So 1. We are not in a 5* but a community of help so the vouvoiement…
2. It’s clear that optimization helps but as I said if you reread the posts it has already been proposed.
3. I wasn’t rude but I find that saying things that mean nothing (wlan ipv6????) serves no purpose other than sowing doubt, creating confusion.
So if the goal is to post for the sake of posting there is Facebook,…
Of course, sorry for offending you.
I called the Swisscom Helpline.
It seems that there are a lot of disturbances on my line which are not adapted to the speeds of my subscription.
A technician will come by Thursday to sort this out.
Thank you for your contributions
@JQ89
Good evening,
Optimizing the Wlan and putting =ipv6 doesn’t mean anything!, as for Facebook I’ll leave it to you I won’t go there
for informality I only grumble when we are rude otherwise it doesn’t bother me
