@Anonym schrieb:
Also bei mir läuft X-Lite ohne Probleme. Hast Du evtl. noch irgendwo eine Firewall dazwischen?
Nein, aber was speziell ist: Ich verwende 192.168.88.0/24 statt 192.168.1.0/24 - ist vielleicht etwas “hardcoded” in der Software? Ich nehme an, ihr verwendet die Box mit 192.168.1.0/24
Untenstehend noch die WireShark Outputs, rot hervorgehoben, dass die ICMP Fehlermeldungen von der MAC / IP der Internetbox kommt.
No. Time Source Destination Protocol Length Info
1 15:58:15.273441000 192.168.88.55 192.168.88.1 SIP 581 Request: REGISTER sip:192.168.88.1 (1 binding) |
Frame 1: 581 bytes on wire (4648 bits), 581 bytes captured (4648 bits) on interface 0
Interface id: 0 (\evice\PF_{B4A1CCF9-853C-4BE9-8E9A-FDC1236D7804})
Encapsulation type: Ethernet (1)
Arrival Time: Nov 21, 2015 15:58:15.273441000 W. Europe Standard Time
[Time shift for this packet: 0.000000000 seconds]
Epoch Time: 1448117895.273441000 seconds
[Time delta from previous captured frame: 0.000000000 seconds]
[Time delta from previous displayed frame: 0.000000000 seconds]
[Time since reference or first frame: 0.000000000 seconds]
Frame Number: 1
Frame Length: 581 bytes (4648 bits)
Capture Length: 581 bytes (4648 bits)
[Frame is marked: False]
[Frame is ignored: False]
[Protocols in frame: eth:ethertype:ip:udp:sip]
[Number of per-protocol-data: 1]
[Session Initiation Protocol, key 6]
[Coloring Rule Name: UDP]
[Coloring Rule String: udp]
Ethernet II, Src: AsustekC_xx:xx:xx (48:5b:39:xx:xx:xx), Dst: AskeyCom_xx:xx:xx (b4:ee:b4:xx:xx:xx)
Destination: AskeyCom_xx:xx:xx (b4:ee:b4:xx:xx:xx)
Address: AskeyCom_xx:xx:xx (b4:ee:b4:xx:xx:xx)
……0…………….. = LG bit: Globally unique address (factory default)
…….0……………. = IG bit: Individual address (unicast)
Source: AsustekC_xx:xx:xx (48:5b:39:xx:xx:xx)
Address: AsustekC_xx:xx:xx (48:5b:39:xx:xx:xx)
Type: IP (0×0800)
Internet Protocol Version 4, Src: 192.168.88.55 (192.168.88.55), Dst: 192.168.88.1 (192.168.88.1)
Version: 4
Header Length: 20 bytes
Differentiated Services Field: 0×00 (DSCP 0×00: Default; ECN: 0×00: Not-ECT (Not ECN-Capable Transport))
0000 00.. = Differentiated Services Codepoint: Default (0×00)
……00 = Explicit Congestion Notification: Not-ECT (Not ECN-Capable Transport) (0×00)
Total Length: 567
Identification: 0×0dc9 (3529)
Flags: 0×00
0……. = Reserved bit: Not set
.0…… = Don’t fragment: Not set
..0….. = More fragments: Not set
Fragment offset: 0
Time to live: 128
Protocol: UDP (17)
Header checksum: 0xf963 [validation disabled]
[Good: False]
[Bad: False]
Source: 192.168.88.55 (192.168.88.55)
Destination: 192.168.88.1 (192.168.88.1)
[Source GeoIP: Unknown]
[Destination GeoIP: Unknown]
User Datagram Protocol, Src Port: 55603 (55603), Dst Port: 5060 (5060)
Source Port: 55603 (55603)
Destination Port: 5060 (5060)
Length: 547
Checksum: 0×8528 [validation disabled]
[Good Checksum: False]
[Bad Checksum: False]
[Stream index: 0]
Session Initiation Protocol (REGISTER)
Request-Line: REGISTER sip:192.168.88.1 SIP/2.0
Method: REGISTER
Request-URI: sip:192.168.88.1
Request-URI Host Part: 192.168.88.1
[Resent Packet: False]
Message Header
Via: SIP/2.0/UDP 192.168.88.55:55603;branch=z9hG4bK-524287-1—a3c7e805b24d850f;rport
Transport: UDP
Sent-by Address: 192.168.88.55
Sent-by port: 55603
Branch: z9hG4bK-524287-1—a3c7e805b24d850f
RPort: rport
Max-Forwards: 70
Contact: <sip:220@192.168.88.55:55603;rinstance=88b91660399b80bd>
Contact URI: sip:220@192.168.88.55:55603;rinstance=88b91660399b80bd
Contact URI User Part: 220
Contact URI Host Part: 192.168.88.55
Contact URI Host Port: 55603
Contact URI parameter: rinstance=88b91660399b80bd
To: “Display Name”<sip:220@192.168.88.1>
SIP Display info: “Display Name”
SIP to address: sip:220@192.168.88.1
SIP to address User Part: 220
SIP to address Host Part: 192.168.88.1
From: “Display Name”<sip:220@192.168.88.1>;tag=cc637e61
SIP from address: sip:220@192.168.88.1
SIP from address User Part: 220
SIP from address Host Part: 192.168.88.1
SIP from tag: cc637e61
Call-ID: 78104YzU3YjhhZWEzY2ViM2JjZTg3MGI5ZGE1ODZjOTI3ZTc
CSeq: 1 REGISTER
Sequence Number: 1
Method: REGISTER
Expires: 3600
Allow: SUBSCRIBE, NOTIFY, INVITE, ACK, CANCEL, BYE, REFER, INFO, MESSAGE
User-Agent: X-Lite release 4.9.0 stamp 78104
Content-Length: 0
2 15:58:15.274416000 192.168.88.1 192.168.88.55 ICMP 590 Destination unreachable (Port unreachable)
Frame 2: 590 bytes on wire (4720 bits), 590 bytes captured (4720 bits) on interface 0
Arrival Time: Nov 21, 2015 15:58:15.274416000 W. Europe Standard Time
Epoch Time: 1448117895.274416000 seconds
[Time delta from previous captured frame: 0.000975000 seconds]
[Time delta from previous displayed frame: 0.000975000 seconds]
[Time since reference or first frame: 0.000975000 seconds]
Frame Number: 2
Frame Length: 590 bytes (4720 bits)
Capture Length: 590 bytes (4720 bits)
[Protocols in frame: eth:ethertype:ip:icmp:ip:udp:sip]
[Coloring Rule Name: ICMP errors]
[Coloring Rule String: icmp.type eq 3 icmp.type eq 4 icmp.type eq 5 icmp.type eq 11 icmpv6.type eq 1 icmpv6.type eq 2 icmpv6.type eq 3 || icmpv6.type eq 4]
Ethernet II, Src: AskeyCom_xx:xx:xx (b4:ee:b4:xx:xx:xx), Dst: AsustekC_xx:xx:xx (48:5b:39:xx:xx:xx)
Destination: AsustekC_xx:xx:xx (48:5b:39:xx:xx:xx)
Source: AskeyCom_xx:xx:xx (b4:ee:b4:xx:xx:xx)
Type: IP (0×0800)
Internet Protocol Version 4, Src: 192.168.88.1 (192.168.88.1), Dst: 192.168.88.55 (192.168.88.55)
Version: 4
Differentiated Services Field: 0xc0 (DSCP 0×30: Class Selector 6; ECN: 0×00: Not-ECT (Not ECN-Capable Transport))
1100 00.. = Differentiated Services Codepoint: Class Selector 6 (0×30)
Total Length: 576
Identification: 0xf2d6 (62166)
Flags: 0×00
Fragment offset: 0
Time to live: 64
Protocol: ICMP (1)
Header checksum: 0×539d [validation disabled]
[Good: False]
[Bad: False]
Source: 192.168.88.1 (192.168.88.1)
Destination: 192.168.88.55 (192.168.88.55)
Internet Control Message Protocol
Type: 3 (Destination unreachable)
Code: 3 (Port unreachable)
Checksum: 0×263b [correct]
Version: 4
Total Length: 567
Flags: 0×00
Fragment offset: 0
Time to live: 128
Protocol: UDP (17)
[Good: False]
[Bad: False]
Length: 547
Checksum: 0×8528 [unchecked, not all data available]
[Stream index: 0]
Method: REGISTER
Message Header
Transport: UDP
Sent-by port: 55603
RPort: rport
Max-Forwards: 70
CSeq: 1 REGISTER
Sequence Number: 1
Method: REGISTER
Expires: 3600
Co
