Hello lads
We are currently experiencing several issues with the remote control connection.
Possible causes/solutions:
- If you have an Apple TV, please turn off Bluetooth.
- For iPhone/iPad users: The TV 2.0 app offers remote control function.
The problem is treated with priority. In collaboration with manufacturers and suppliers, we work hard to find a solution as soon as possible. It is not yet possible to establish the duration. We apologize for the inconvenience caused.
Best regards
TizianaD
Swisscom
:smileyindifferent:I think the title of one of the most read posts on the German-speaking cousins forum says it all:
New Swisscom TV Box available at UPC Cablecom
well…..the TV no longer works well, there are fewer channels in Italian…..if the quality of the box also collapses….you might as well switch to the competition….
As Tiziana says, Swisscom is aware of the problems and is working to resolve them. The competition also has problems. The 30 hour replay from them doesn’t work. Try reading their forum too.
http://community.upc-cablecom.ch/hives/b001af61b3/summary
Their blog doesn’t even exist in Italian
Our previous box, however, was fine. Be confident.
I too have the same problems. TV box freezes, channels skip, Teletex goes crazy every now and then while spinning. I’m waiting
to fix these problems. Old decoder never had problems.
mirobiondo wrote:
Good morning, since I installed Swisscom TV 2.0 I have only problems. The TV box does not respond to remote control commands, it freezes and then goes on its own. I have already reported the problem several times to Swisscom and they are working on it. Is there anyone else in the community having the same problem?
PS. even the remote control from 3 meters away doesn’t always work
