WLAN to TV box connection out of date?
Seischeicka36
Level 2
1 of 7
Our WLAN box and TV box are linked as in photos (using the 'C'-shaped units next to phone / tv box). This general set up is probably 15 or so years old. I was looking to replace the 'C' shaped units, but can't find similar in SwissCom shop. Is there a 'newer' way to link the WLAN and tv box without using cable? Thanks in advance for any suggestions!
ACCEPTED SOLUTIONS 2
Accepted Solutions
monserrate
Level 1
6 of 7
Go for WLAN-Box 2,
Barcode Label Maker by :
Seischeicka36
Level 2
7 of 7
Thanks everyone. Fixed by upgrading Swisscom box.
6 Comments 6
Black Mamba
2 of 7
@Seischeicka36
Swisscom proposes the WLAN Box 2 or 3, available on the site or in the Shop
My home network - Help | Swisscom
Un "Like" fait toujours plaisir / Valider une réponse comme "Solution"
Seischeicka36
Level 2
3 of 7
Thank you! I will give it a go.
bitracer
4 of 7
You‘ll need a WLAN-Box 2, since the WLAN-Box 3 is not compatible with your router.
You need only one device.
Seischeicka36
Level 2
5 of 7
Thank you! I’ll go to Swisscom shop today.
monserrate
Level 1
6 of 7
Go for WLAN-Box 2,
Seischeicka36
Level 2
7 of 7
Back to top
