cancel
Showing results for
Search instead for
Did you mean:
Remote control
Highlighted
1 of 3
Worst remote control I've ever had. It keeps saying batteries are discharged even if it's not true, voice control doesn't work I thought it was broken, so I changed it and it's the same thing. Does someone knows if there's an alternative? (possibly not from Swisscom)
2 Comments 2
Highlighted
2 of 3
Sure, change to a Android-TV-Box like from Xiaomi or an Apple TV, but you cant get just Swisscom TV fully on there!
Its the best option to contact the hotline and ask them for a refund or a switch of the devices - they will help you for sure.
Gruess, Cordial salids, Cordialement, Cordiali saluti
Dominik
https://dev.exena.ga
Highlighted
3 of 3
@GregorioMeyer
request the change of the current remote control
call the hotline at 0800 800 800
contact by form via the Swisscom customer area
go directly to a Swisscom Shop
change to a universal remote control
most recent televisions have one
otherwise search on a commercial store
Back to top
