cancel
Showing results for
Search instead for
Did you mean:
LAN connection through Google WiFi
Highlighted
Level 1
1 of 1
Hello,
I am having trouble with my Swiss TV box when connected directly to a Google WiFi access point via network cable. The box is online, I can go to settings and see an IP address, system uptime, etc and even scroll through the TV guide which shows the correct current listings. However, when I select a channel it says “No TV signal is detected”.
I have a second TV box wired directly to the Swisscom Internet box 2 which is working completely fine but has the same issue if I connect through a Google WiFi access point. The WiFi mesh is working and is not generating any issues for me asides from this. Any ideas on how to resolve?
Thanks
Back to top
