cancel
Showing results for
Search instead for
Did you mean:
Ethernet Speed
Highlighted
Level 1
1 of 2
I have attached a Internet Box Plus to Fiber. I get 1gb on Ethernet connection 1, but only 100 MB on the other three connections. Is this normal or am I doing something wrong? Thank you
1 Comment
Highlighted
2 of 2
you device are 1GB capable?
Checked the cables?
Checked the driver settings on your device if it's configured to 1 GB?
Also, not sure if the integrated switch of the internet box plus (which is a very old router anyway) can handle 1 GB.
Check the router GUI and see the speed of each device.
Back to top
