cancel
Showing results for
Did you mean:
SOLVED
Switch from swisscom tv to bluetv means Lost functionalities and higher cost.
Nauttoviold95
Level 2
1 of 4
Hello
can you please explain if switching to bluetv means we should buy a new swisscom box/remote. The remote we have dors not seem to work with new Samsung Tv 4052
also, in the ‘old’ swisscom mode we were able to replay and record programs, why bluetv is now charging for an existing offer?
thanks for clarifying
ACCEPTED SOLUTION 1
Accepted Solutions
LeylaG
Level 2
4 of 4
Hello @Nauttoviold95
You currently have the HD TV-Box. Unfortunately, it doesn't support the new blue TV update.
You have the possibility to go in a Swisscom Shop and get an UHD TV-Box for free 🙂
Regarding the subscription, you have the option Swisscom TV L, means 7 day Replay and up to 1'200 hours of recording
Hope it helps!
Un like fait toujours plaisir 😉 Une réponse t'a aidé? -> Accepte-la comme solution!
A like always brings a smile 😄 Don't forget to accept helpful solutions
3 Comments 3
Black Mamba
Level 2
2 of 4
NO 😁 on the contrary it is to avoid precisely that
blue TV as an app on the TV (OTT)
Swisscom is taking the first step towards OTT (over-the-top content) in the TV sector. The blue TV app will be available from October on Samsung Smart TVs (2017 and newer models). Compatibility with other smart TV vendors is under study. The year of manufacture can be found in the model designation (example: UE55RU7170). Devices with the following designations have been on the market since 2017: Q, RU, LS, R, NU, N, MU, M
The blue TV app only works through the TV directly
It is not possible to install the application on the TV-Box
The idea is that the application works without the TV-Box
please specify which programs would be billed
Nauttoviold95
Level 2
3 of 4
Thank you Black Mamba
I am certainly confused by the blue tv options . In swisscom bluewin old mode, I could replay programs I missed and I could record programs, at no charge. It seems I need to buy an extra package in bluetv to do the same.
Not sure how to do change language options - for dual language programs , not sure how to add subtitles ...
very frustrating, not sure is the samsung smarttv or bluetv  not very intutive/user-friendly  ... it should not be so difficult to  find out how to keep existing features
thanks again, I appreciate your help
LeylaG
Level 2
4 of 4
Hope it helps!
Back to top
