cancel
Showing results for
Did you mean:
SOLVED
Second Blue TV with old TV Box
Vattienna17
Level 1
1 of 3
Hello,
I am looking to install a second TV box to run simultaneously  in a normal TV(not smart). I saw on the swisscom website that I can buy a new TV box and pay an additional 5.- per month for the streaming service.
I already have an old TV box (Swisscom TV Box 1) that works perfectly. Can I use it instead of buying a new TV box? If so, how? Do I only have to plug and play or do I have to request for something?
p.s. I know there will be no UHD but that is ok for this TV
Thank you very much in advance
Edited
ACCEPTED SOLUTION 1
Accepted Solutions
DomiP
Level 1
2 of 3
@Vattienna17 you can simply plug in your second tv-box to your tv and ethernet. Then you have the option to book the Package (for 5.- every month) directly on the tv-box.
Alternatively you can contact the Hotline or your CustomerCenter at https://swisscom.ch/myswisscom so they can enable this feature for you.
Afterwards you can use both boxes simultaneously :-).
I hope this helps.
Gruess, Cordial salids, Cordialement, Cordiali Saluti, Cheers!
Dominik
2 Comments 2
DomiP
Level 1
2 of 3
I hope this helps.
Dominik
Vattienna17
Level 1
3 of 3
Thank you very much for the quick and succinct answer. I will try it!
Back to top
