cancel
Showing results for
Did you mean:
SOLVED
Dolby atmos or audio passthrough support in Swisscom Box
xau20
Level 1
1 of 3
Hi all,
I would like to know if it's supported by the "Box" audio passthrough for example in applications like Netflix or Prime Video or Plex if a movie or TV Show has it so if we have a soundbar connected will it let the audio through to be decoded by the sound system?
Thanks
P.S.: Sorry that I am not writing in french but I am only starting
ACCEPTED SOLUTION 1
Accepted Solutions
UrsSch
Level 1
3 of 3
Hi @xau20
The IP1400 UHD Box and IP2000 Swisscom Box are supporting passthrough mode up to DD+ 7.1 but no Dolby Atmos based on DD+ not Dolby Atmos based on TrueHD codec.
Ich bin Swisscom Mitarbeiter und arbeite im Bereich SwisscomTV Entwicklung
2 Comments 2
JoelV
Level 1
2 of 3
Hey @xau20
Thanks for your post. 🙂
Since you posted your question in the french part of the community, i moved it to the right language.
I just asked an expert. Hope we'll get an answer soon.
Best regards and i wish you a lot of success with learning the french language. 😉
IvanH
Business Owner | Communications Manager Swisscom
UrsSch
Level 1
3 of 3
Hi @xau20
Back to top
