Unique flexibility: Samsung Galaxy Z Flip
100% helpful (1/1)
The Galaxy Z Flip reveals a completely new era of smartphones. Unfolding the compact, palm-sized clam shell, the new flexible, Ultra-Thin Glass Infinity-O display transports you into the future. It offers the unique flexibility to enjoy a completely new way to interact using your smartphone. The new Samsung Galaxy Z Flip is now available at Swisscom in the colors Black Mirror and Purple Mirror.
> Order now
Highlights Galaxy Z Flip
  • 6.7" Ultra-Thin Glass Infinity-O Dynamic AMOLED (FHD+ 2220 × 1080), 1.06" sAMOLED 300 × 111
  • Dual rear camera: 12 MP Wide (f/1.8) + 12 MP Ultra-Wide (f/2.2), Front camera 10 MP (f/2.4)
  • 8 GB RAM, 256 GB Memory
  • 3300 mAh Battery with Fast Charging
  • Side fingerprint
  • NanoSIM + eSIM
  • Wireless PowerShare
Compact on the outside, immersive on the inside
The compact size of the Galaxy Z Flip fits perfectly into the smallest of pockets and the palm of your hand, while at the same time utilizing the most advanced technology so that you can enjoy multimedia and productivity at the highest level. The new Ultra-Thin Glass display with integrated selfie camera is cleaner and brighter, and transports you into the future of smartphones. The unfolding experience has another even more exiting dimension thanks to the unique flexibility of the new hinge design, so that it holds any position, inspiring new ways to use your smartphone.
New UI, new possibilities
The Galaxy Z Flip user interface is optimized with the Seamless App Continuity. Check your notifications, calls and messages on the discrete Focus Display on the outside, and simply swipe them or unfold to take calls and check your social media feeds for the latest images on the flexible display. When the Galaxy Z Flip is folded 90 degrees, the camera adapts to 'influencer-ready' mode so that you can film using the selfie or the main camera while holding the phone comfortably in your hand or positioning it anywhere you like.
The main camera's wide or ultra wide lens helps you take the highest quality selfies that you can then preview on the Focus Display while safely and comfortably holding the phone in your hand or resting it anywhere you like. The Galaxy Z Flip unfolds new possibilities.
Flagship performances
Compact size, but no compromise when it comes to the best flagship performance. The OctaCore 7 nm processor is super-fast and energy efficient. It is also possible to have two phone lines with different numbers thanks to the SIM slot and integrated eSIM module. Wireless Charging and PowerShare let you charge your Galaxy Buds or Galaxy Watch on the go. There are three pro-grade cameras; a wide and ultra wide camera for the main module, and an elegant selfie camera, all fully integrated into the Ultra-Thin Glass Dynamic AMOLED display. The fingerprint sensor is integrated in the power button, securing your device and enabling you to make payments with Samsung Pay quickly and comfortably.
The new Samsung Galaxy Z Flip is now available at Swisscom in the colors Black Mirror and Purple Mirror. You can find the smartphone displayed in the following Swisscom Shops:
Amriswil (FN), Bern Bahnhof, Bern Bubenbergplatz, Luzern Bahnhofstrasse, Schwyz, Stans, St. Gallen Neugasse, Winterthur Stadthaus, Zürich Füssli, Fribourg, La Chaux-de-Fonds, Lausanne Bergières, Monthey
Do you have more questions about Samsung Galaxy Z Flip? We appreciate your comments.
Was this article helpful? Yes No
Contributors
