Automatic standby mode for Swisscom TV-Box options
No ratings
Have you noticed that your Swisscom TV-Box switches off automatically if you haven’t used the remote control for a while, or if you only switch off the TV, not the Swisscom TV-Box? This article explains how quickly your TV box goes into standby mode and how to deactivate this function.
The Swisscom TV-Box is preset to go into standby mode if it has been idle for a long period. This means that the TV box will automatically go into standby if you haven’t pressed a button on the Swisscom TV remote control, or if you only switch off the TV, instead of switching off the TV box as well. If a programme is running on your Swisscom TV, the TV box will switch to standby mode after 4 hours, or after 12 hours in radio mode. Originally, TV and radio both switched to standby after 4 hours. However, in response to feedback from the Swisscom Community, the number of hours in radio mode was increased from 4 to 12 hours.
How can I deactivate this function?
Go to Settings → System → Automatic Settings to deactivate automatic switch-off / power-saving mode and to switch it back on again.
Was this article helpful? Yes No
Contributors
