cancel
Showing results for
Search instead for
Did you mean:
Dual language on TV Air
Highlighted
Level 1
1 of 2
How to switch dual language with latest TV Air? I found related topics but none of the options are available anymore.
1 Comment
Highlighted
Level 6
2 of 2
you can change the language in the language menu at the top right corner of the home page.
Kind regards
Freundliche Grüsse, Dominik
Cordial salids, Dominik
Cordialement, Dominik
Cordiali saluti, Dominik
Hat's geholfen? Duume drücke. War's die Lösung? Häckli drücke.
Back to top
