cancel
Showing results for
Search instead for
Did you mean:
SOLVED
Downloaded recordings not dual language
Highlighted
Level 1
1 of 3
Downloaded recordings do not support dual language. Even if SRF or RTS is stating that the film is in English, there is no option to change language for a downloaded recording.
Anyone know if this will be implemented?
MOST HELPFUL ANSWER
Accepted Solutions
Highlighted
Community Manager
2 of 3
Hello @MFnummer6
Thank you for your feedback.
Our developers are working on it!
You should be able to switch the audio track soon. I can't give you a specific date I am afraid.
Thank you for your patience.
Have a good day,
Un like fait toujours plaisir 😉 Une réponse t'a aidé? -> Accepte-la comme solution!
2 Comments
Highlighted
Community Manager
2 of 3
Hello @MFnummer6
Have a good day,
Highlighted
Level 2
3 of 3
It's almost May as and this is STILL a problem
Back to top
