cancel
Showing results for
Search instead for
Did you mean:
SOLVED
WLAN Power and Additional information
Contributor
1 of 5
@GuidoT
Hello everyone,
I am wondering to understand how tht WLAN works.
I noted that the Transmitting power in 2.4Gh goes from 15.5 and then drain to 0, and sometime I only have 15.5 on Ant0 and 0 on Ant1/2.
And sometime even RSSI in 5Gh Ant1/2/3 is 0.
It's this the correct behaviours?
Other information are not so easy to understand by the way.
Thanks GuidoT and Happy easter.
iPing
Former Swisscom Staff
Edited
MOST HELPFUL ANSWER
Accepted Solutions
Swisscom
4 of 5
Hi
0 is only a display error. There is a bug in the Broadcom driver with no impact on real life. We are waiting for Broadcom to fix it. I already explained that in my article about how to detect if the 5 GHz WLAN is defect.
Guido
Head of Access & Communication Services @ Product & Marketing Department, Swisscom (Schweiz) AG
Edited
4 Comments
New Member
2 of 5
hi dude, ive the same prob. you find an answer?
Contributor
3 of 5
Hi, no. No answer so far. I hope that someone from swisscom may answer. This may explain the poor Wireless coverage and speed. The box behivour seams anyway really strange. As far I understand, all value can varies for sur, but having 100% then 0%, then 100% it's more a misfunctioning comming from the Askey box and/or vestiacom.
Swisscom
4 of 5
Hi
Guido
Edited
Contributor
5 of 5
Merci Guido, I wait on a new update to see what happend. By the way I have a other IB2, without the Homedevice port at the back, that simply not work on 5GHz.
