cancel
Showing results for
Did you mean:
VDSL speed with Zyxel XMG3927 is 70mbps but 85mbps with Internet Box 3?!
swisspol
Level 1
1 of 4
Hi!
I successfully set up the Zyxel XMG3927 as a modem in bridge mode for my Swisscom VDSL connection to replace the Internet Box 3. However the speed reported by fast.com is 70 mpbs downstream while before I had 85 mbps?
In the "System Info" panel of the web UI of the modem, it says:
Rx:75471 Tx:31429 (Kbps)
I assume that's the nominal DSL speed, which is consistent with what I observe.
How come the Swisscom modem is quite faster?
PS: I have "S" internet access with:
- 100 Mbit/s max. Download
- 100 Mbit/s max. Upload
3 Comments 3
swisspol
Level 1
3 of 4
Hi! Thanks for getting back to me. I looked at all the links and it's people having problems setting up the modem / router, but everything works for me - I even got the TV working this morning. My only problem is the nominal VDSL speed which is not as high as before with the IB3.
Do you have any other ideas?
Black Mamba
Level 1
4 of 4
@swisspol
thanks for feedback
for technical questions contact
Support and Service – products | Swisscom
Support from My Service experts, mobile phone repairs and free courses: find the right solution for technical issues, faulty devices and usage questions
Technical support
My Service experts can help you with technical problems and device issues. On the phone, in a Swisscom Shop or at home.
Back to top
