cancel
Showing results for
Did you mean:
SOLVED
Data roaming in Germany\
Ironhero2020
Level 1
1 of 3
I am swisscom inOne go mobile customer. On 16 December 2020 I went through Frankfurt airport on transit and had extremely frustrating experience with data roaming on my mobile. Voice roaming was OK, however data roaming was not working at all. Signal indication was good but no internet connection. I needed to show some document from the cloud at check in counter and waited for download for 5 minutes and gave up. Tried to see search some information from Frankfurt airport web page, no luck.
Should I've done something to activate roaming?
ACCEPTED SOLUTIONS 2
Accepted Solutions
Black Mamba
2 of 3
@Ironhero2020
you have to test a reboot / reset of the mobile
the problem could also come from a limited subscription package or simply a lack of network at the location?
if the problem persists contact the Swisscom Hotline
DomiP
3 of 3
@Ironhero2020 as already told by @Black Mamba try to restart your mobile.
I did also had this problem sometimes i went to Rust, Germany. I called the Swisscom Hotline and they logged my profile off and logged it in again.
It is more a technical issue from connecting the Device correctly to the Systems of the other Providers and Swisscom.
Otherwise i suggest you to use Free WiFi at the Airport which is provided by Fraport AG, the Owner of Frankfurt Airport. If you are scared of getting spoofed or spied by hackers, i would install a VPN-App. If you have Swisscom inOne Home at Home you can also create a VPN directly to your Home Network.
Gruess, Cordial salids, Cordialement, Cordiali saluti
Dominik
2 Comments 2
Black Mamba
2 of 3
@Ironhero2020
DomiP
3 of 3
Dominik
Back to top
